Old 11-02-2016, 09:09 PM   #1
lanehicks76
Late model AC swap in 72 C10
Hey guys, I found a similer post to my question, but I need some more info. I am currently doing a 98 vortec swap into a 72 c10 and I am swapping AC system too. Before I cut the evaporator box to fit the 98 evap. is there different make, model or year that is closer to the specs of my 72 evap.? I am looking for a closer fit, so little fab work has to be done. Thanks in advance.
lanehicks76 is offline   Reply With Quote
Old 11-03-2016, 06:50 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Late model AC swap in 72 C10
Evaporator for an 87 fits right in there.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 11-03-2016, 09:40 AM   #3
lanehicks76
Thanks for the info do you know if they drier from the 98 will fit on the 87 evaporater
Old 11-03-2016, 11:37 AM   #4
B. W.
B. W.'s Avatar
X2 - IIRC 78 to 91 full size GM truck evaps are all the same (if my notes are corrcect)
I'm using the serpentine drive setup off of a early 90's full size truck with the R4 compressor, stock hose assy, stock condenser, stock accumulator (all for that year). the orifice tube fits into the stock pipe, you can place the OT up near the condensor or back before the evaporator. GM did it both ways, I prefer nerar the evaporator. You can play with different orifice tubes to "fine tune", I start with the stock one & it usually works. I like to see 38° at the center duct & can acheive this most of the time. In 96 Gm switched to metric fittings, you can mix or match these parts but may have to build custom hoses ore replace hose ends to match the fittings. There are a couple of different versions of teh evaporator, same dimensions but the exit tube is shaped differently. The one listed below is curved & moves the accumulator away from the engine toward the pass side fender
Car Quest part #'s (may be old #'s, may need to cross reference)
Evaporator T54275
hose assy T56155
pipe (from condenser to evaporator) 15-33084 will have to bend/shorten/lengthen (or just custom build) orifice tube fits in this
accumulator T33219
orifice tube T38638
R4 compressor (some will have different heights where the hose maifold bolts on)
condenser - mid 90's full size GM
B. W. is offline   Reply With Quote
Old 11-03-2016, 03:35 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Late model AC swap in 72 C10
Every fitting on mine worked. I went to 134A and never looked back. The drier up front I ditched for the acumalator on the vaperator.Put the orfice tube in the lower line at the fittings under the battery. Works great.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
