Old 11-02-2016, 10:16 PM   #1
custom10nut
custom10nut's Avatar
Gap in heater core inlet/outlets.
I have a non-A/C truck.
There is a gap about 1/4 inch on both the inlet and outlets between the tubes and the heater box.
Has anyone filled this gap to "dress things up" under the hood?
It looks like there should be a filler off putty there, and it would look a lot "cleaner" if there was.
I'm think about using a black plumber's caulk. It's semi permanent, and sets up with a flat finish.
Did these trucks come from the factory with this gap? Or was there some sort of gasket/filler putty there?
custom10nut is offline   Reply With Quote
Old 11-03-2016, 01:38 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Gap in heater core inlet/outlets.
I don't know if they came from the factory with the gaps sealed or not but I have seen quite a few trucks with caulk around the tubes. I would say just finish it off how ever you like it.....
LockDoc
Leon
Old 11-03-2016, 08:16 AM   #3
custom10nut
Yeah, me too. I just wondered about it.
One thing I love about these trucks, is that no two are exactly alike.
There were no "cookie cutter" option packages that couldn't be altered (to a point) by either factory order or dealer install, so it's an adventure for me whenever I see one in a salvage yard or even a show.
