Old 11-03-2016, 10:41 AM   #1
dmartin1
dmartin1's Avatar
c20 into a 4x4 using oem gm k10 equipment?
Can anyone see a problem with using a 1972 c20 frame and putting the oem equipment off a 71 k10 onto it?
I have the fabrication ability and large welders, lifts etc.
Does anybody know if this will work, or is a c20 frame dimensions too different to work with the k10 crossmembers?
If it helps any, i also have a 1978 k20 i could use parts from or even the axles ( dana front, 14 bolt rear).
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 11-03-2016, 10:57 AM   #2
Bigdav160
Bigdav160's Avatar
Re: c20 into a 4x4 using oem gm k10 equipment?
Is it a leaf spring or coil spring frame? I would think a leaf spring frame would be easy. Probably bolt in.
Coil spring frames are a little different shape and has a large central crossmember.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-03-2016, 04:44 PM   #3
First c10
First c10's Avatar
dmartin1, 2wd to 4wd will take some work. check out 7dee2's build
7DEE2
He did it but used 3/4 or 1 ton running gear but the same work is need to make a 2x4 to a 4x4.....
hope this help
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 11-03-2016, 09:51 PM   #4
franken
7DEE2
He did a frame swap which is a bit different. I think the unanswered question above about whether the current truck is leaf or coil springs is valid. I seem to recall that rear WMS is slightly (1-1.5") different on 2x4 and 4x4 67-72 trucks.
As for the 78 K20, the front would bolt up to a 67-72 4x4 frame but the frame brackets won't be on a 2x4 frame so some fab would be needed. The 78 rear has spring perches further out and one shock mount is on the wrong side. Those would need to be moved.
The front crossmember is also different on a 4x4 as I recall.
franken is offline   Reply With Quote
Old 11-04-2016, 02:49 AM   #5
andrewmp6
As long as both frames are the same wheel base it should work maybe be bolt in.
andrewmp6 is offline   Reply With Quote
Old 11-04-2016, 08:33 AM   #6
LowLifeS10
LowLifeS10's Avatar
Im in the progress of converting a -72 c20 to 4x4 by using a blazer k5 -82 as a donor. Im using all the brackets from the blazer except the most rearwards. The brackets needs to be modified a lil bit.
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059
Front/back Porterbuilt dropmember, Accuair, LS1/4L60e
Chevrolet C20 -72 C20 to K10/20 conversion, LS power.
LowLifeS10 is offline   Reply With Quote
Old 11-07-2016, 10:35 AM   #7
7dee2
7dee2's Avatar
We did explore using our donor 84 K3500 3+3 frame early on but ultimately acquired a C20-30 Longhorn frame that we converted to 4wd. We used a generation correct 4x k-member and retrofitted both front (71-72 K20) and rear (mostly 84 K3500) suspensions utilizing all 1 ton drw running gear.
First c10 is correct in that we did use the style parts you describe. I don’t see any problem using the 71 K10 stuff up front on your C20, the front position hangers are a bolt on most of the work is in the front rear position and the k-member.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
