Old 11-03-2016, 02:08 PM   #1
Trent4181
Trans swap help
I have a '71 c10 with the th350 auto. Reverse is going out and it can't decide going 50+mph weather it wants to be in 3rd or 2nd. So I'm just gonna get a new trans. I'm wanting to get a nv3500 5 speed. Is there anyone out there who has done this that could give some helpful tips on the swap?
Trent4181 is offline   Reply With Quote
Old 11-03-2016, 02:36 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Trans swap help
If reverse is out then third is going with it (Direct Clutch)
What rear gear? 3.08:1? That would be terrible with a manual trans.
I can't help much on the NV3500 swap. Is the shifter going to be too far back? Are you going to use a hydraulic clutch?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-03-2016, 03:30 PM   #3
Trent4181
I'm pretty sure it has 4.11's or 4.56's I know that in third, going 60-65 I run about 4500 rpm. And yes, I plan on getting a hydraulic clutch.
Old 11-03-2016, 04:36 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Trans swap help
You might find some helpful info in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
LockDoc
Leon
Old 11-03-2016, 05:31 PM   #5
Trent4181
LockDoc
Not very much help, I need to add a master cylinder, pedal, everything I need that an auto isn't set up for, plus the article in mention is on a t5, not nv3500
