Old 11-03-2016, 08:41 PM   #1
beanious
Smile LED Flasher that works with 67-72 Chevy Trucks
All, this last week I went through the process of changing all my bulbs to LED and the flashers too. This should make them last "almost" forever and alleviate blown out bulbs. I have documented the pictures and the process I went through in finding a flasher that actually worked for our trucks. See below, 4th and 5th pics were the one that worked. I got it from Summit Racing part# UPD-90652.
beanious is offline   Reply With Quote
Old 11-03-2016, 08:41 PM   #2
beanious
Re: LED Flasher that works with 67-72 Chevy Trucks
1st pic original relay (Did not work with LEDs)
Old 11-03-2016, 08:42 PM   #3
beanious
2nd pic second relay (Did not work with LEDs)
Old 11-03-2016, 08:43 PM   #4
beanious
3rd pic third relay (Did not work with LEDs)
Old 11-03-2016, 08:43 PM   #5
beanious
4th pic fourth relay (Works with LEDs)
Old 11-03-2016, 08:44 PM   #6
beanious
5th pic fourth relay installed (no black boot on the top relay, black boot on bottom relay)
Old 11-03-2016, 08:45 PM   #7
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Good stuff,
Please post the part number of the good one.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-25-2019, 09:52 PM   #8
Bellinbiker
I have had issues trying to figure this out all year. I finally crossed the wires on the bottom flasher and it worked!! I am using led flashers from auto zone. I have 4 different flashers and the only thing that worked was crosses the wires on the bottom flasher.
Bellinbiker is offline   Reply With Quote
Old 06-26-2019, 10:10 AM   #9
ga-stepside
ga-stepside's Avatar
Yep! I went through that nightmare on my AMX. It all worked on the bench but not in the car, finally dawned on me to swap the flasher wires in the car. Polarity matters with LEDs.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 06-26-2019, 01:45 PM   #10
EagleChief
EagleChief's Avatar
I'm sub'd for this. Going to ask a "dumb" question, though - What's the black adapter, or boot, part for? Is that just to make it fit the fuse block? And, is that grounded to your brake pedal?
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 06-26-2019, 02:28 PM   #11
Bellinbiker
I didn’t have a boot, I think it’s just a stock photo. The flashers that I’m using now don’t have a ground wire. Just ground wherever you can.
Old 06-26-2019, 03:03 PM   #12
ga-stepside
The flasher that have that wire, it is for ground and needs to be hooked to ground. Some others do not have the ground wire, mine don't.
1967 C10 Step side
1970 AMX 390
Old 10-08-2019, 02:00 PM   #13
Montierth
Montierth's Avatar
Do our trucks need 1 or 2 of these?
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 10-08-2019, 02:11 PM   #14
Smitty
Smitty's Avatar
I'm pretty sure you need to use the same flasher for the emergency flashers as well. So they both have to be the same.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 10-08-2019, 02:29 PM   #15
beanious
Thumbs up Re: LED Flasher that works with 67-72 Chevy Trucks
I replaced both, one for turn signals and one for hazzards.
Old 10-08-2019, 02:54 PM   #16
Montierth
Montierth's Avatar
Just ordered them. Thanks
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 10-08-2019, 03:24 PM   #17
Andy4639
Old member
Andy4639's Avatar
There are a bunch of post's on this subject.
Been running these for years. The boot changes the polarity on the flasher. Been there done that.
Make sure all the wires are ran the same. Make sure everything is grounded good also.Always use the grounded flasher's for LED lights and yes you will need 2 of them if you have hazards.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-09-2019, 03:21 PM   #18
Robznob11
Robznob11's Avatar
Great info Andy! Just a fyi to all. I have an easy wiring harness in my truck and the polarity on the turn signal flasher is opposite of the hazard flasher. Now that will make you pull hair out wondering why they work on hazard but not turns lol. In a pinch load resistors will work with stock flashers. But im not a fan of the thought of a direct short on purpose 😬
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-09-2019, 04:47 PM   #19
Montierth
Montierth's Avatar
Thanks for the fast response. Awesome wealth of info on this site from everyone! Ordered the parts on amazon and coming this week.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 05-15-2020, 02:23 AM   #20
ace347
ace347's Avatar
I've got a question about this very subject. Going through the teething pains of switching to LEDs on my 71. I used some Oriely factory replacement relays and they sort of work for the most part. I have tried some "LED Specific" flashers from LMC that gives me all kinds of problems.
The front lights and tail lights blink like normal, albeit slow. However, my side markers don't blink nor do my LED dash indicators. And when the head lights are on nothing works right.
my question is, will these flasher fix all my ailments?
ace347 is offline   Reply With Quote
Old 05-15-2020, 08:39 AM   #21
Robznob11
Robznob11's Avatar
Here are some things I have had reported back from customers . Many say that the polarity is opposite between the turns and the flashers. Meaning you need 2 flashers and only one needs the polarity reversed. Usually the turn side. I have included a pic from a customer and fellow board member Mac’s Garage on his solution. He has found a Napa brand flasher no ground strap that works and blinks proper speed. And also an adapter to reverse the one flasher.
LED TAILS
Old 05-15-2020, 09:02 PM   #22
ace347
ace347's Avatar
I'll check these out. I'm just not sure if I have an issue elsewhere. One thing that makes me wonder is that my turn signal lights on the dash don't seem to be working. The gauge cluster circuit board is the all original. When I replaced all the dash lights with Leds I looked at the board and didn't see any issues. Had to replace a few sockets aswell.
Old 05-16-2020, 09:43 AM   #23
Andy4639
Old member
Andy4639's Avatar
Ok, this maybe some of the trouble.
Well it's all new from LMC. LEDs, fuse box, everything.
LMC has had a bunch of wiring issues with the relay kits for the head lights, there are many post on here about the wires being crossed up in the kits. I would be inspecting these parts good.
I would be looking at the half moon connector under the dash. I have had trouble before with them not matting up good and the pins coming out of the plastic holders when trying to connect them. All your turn signals and brake lights go through this connection. Just take your time. Check each wire with a test light and find where the juice stops.
Old 05-16-2020, 10:52 PM   #24
ace347
ace347's Avatar
Now that you mention that. I had to repin that particular connector with the original plastic to get that to work. Took me a while to figure out what was going on. I never used a test light on it though. Might look into that next.
Old 05-15-2020, 08:41 AM   #25
Andy4639
Old member
Andy4639's Avatar
That's hard to say since we have no idea what the wiring looks like but if it was me. I'd be buying them and checking all the grounds.
