Old 11-03-2016, 09:29 PM   #1
GSP7
GSP7's Avatar
Tires, BFG KO or Pro Comp AT Sport
Ive been running BFGs on both My trucks
315/75/16...Im looking at Pro Comps AT or BFG K02, kinda looking at the TOYO open country AT2 also
Which do you like? comments?
I dont see Toyo at much but they have a 65,000 mi warranty
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 11-04-2016, 10:41 PM   #2
obijuan
Re: Tires, BFG KO or Pro Comp AT Sport
Toyo outperforms in every way in South Texas. Which tire can depend on your location. I'd still tend toward toyo at 2. I've sold all three of those tires professionally for several years now and even though the new procomp at offer a helluva warranty, you'll probably use it. Bfg k02 is an excellent tire but lacks the heavy duty construction that I feel a truck tire needs. Side by side feel the sidewalls and firmness of the two. Toyo has better curb appeal here too.
obijuan is offline   Reply With Quote
Old 11-06-2016, 04:53 PM   #3
GSP7
GSP7's Avatar
Originally Posted by obijuan View Post
Toyo outperforms in every way...Bfg k02 is an excellent tire but lacks the heavy duty construction that I feel a truck tire needs. Side by side feel the sidewalls and firmness of the two. Toyo has better curb appeal here too.
I found the that to be untrue
Toyo Open Country A/T
Sidewall plies: Two poly
Tread plies: Two poly, two steel, two nylon
BFGoodrich All-Terrain T/A KO
Sidewall plies: Three polyester
Tread plies: Three poly, two steel, one nylon
Fourwheeler test:
Hankook, BFGoodrich & Toyo Tire Test.....Oddly enough, when we checked the durometer (hardness) readings of the treads and sidewalls, all three had identical readings of 62 and 52, respectively......
Google search, I haven't found any legit worth while comparison tests between Toyo at and BFG KO
Old 11-06-2016, 07:02 PM   #4
obijuan
Key word here is feel. Advertised plies vs actual sidewall rigidity.
Old 11-06-2016, 08:55 PM   #5
GSP7
GSP7's Avatar
feel?
Old 11-06-2016, 09:27 PM   #6
obijuan
Originally Posted by GSP7 View Post
feel?
Yes. Feel as actually touch the tire.I have sold and used these tires for several years. Bfg sucks.
Old 11-06-2016, 09:33 PM   #7
dieseldawg142
dieseldawg142's Avatar
got toyo open country m/t's on one truck and bfg mud t/a's (the original ones) on my other truck either one of them is about all i'll use. did have a set of pro-comp XT's, good traction.....for a VERY short time, they were bald in less than 2 yrs. and their flippin' noisy, noiser than the 38's on my crew.
Bf's i bought in '99, still going strong, never had a flat with them, ever.
same with the toyo's, 8 or 9 yrs and in excellent shape, very quiet for a large tire (38x14.50R16) excellent load capacity as well.
you cant really go wrong with either one, whatever you personally like & is in your price range..
dieseldawg142 is offline   Reply With Quote
Old 11-06-2016, 10:45 PM   #8
Bladeboy1998
I wore through a set of ko2 in about 9k miles, that's the second set of bfgarbages I have had, and the last I will ever have. I got cooper's and I will never go back. I'VE heard great reviews on the toyos, and would have gotten them but the cooper's were my warranty replacements and I'm glad they were.
Bladeboy1998 is offline   Reply With Quote
Old 11-07-2016, 10:19 AM   #9
steelhorse
steelhorse's Avatar
I have used BFG's and Pro comp all terrains. I liked the pro comps best and got better wear out of them. I am currently using Nitto terra grapplers and have gotten the best wear I have ever gotten on a 4x4.
steelhorse is offline   Reply With Quote
Old 11-07-2016, 12:40 PM   #10
Orange Crate
Orange Crate's Avatar
I had the old BFG KOs and got 65,000 miles out of them (five tires rotated religiously). I will be looking at a new set of KO2s to complete my build pretty soon. Sub'd.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 11-15-2016, 01:03 AM   #11
K20super
I have procomps in the past and had issues with them cracking where the side wall meets the bead as well as several of our customers at the four wheel drive shop would not recommend them at all
K20super is offline   Reply With Quote
