Old 11-04-2016, 01:40 PM   #1
ChuckLee
Does the 4l60/4l80 lsx trans mount work for t56?
simple question, just haven't been able to really find the answer i need.
i have a 1969 C10 longbed
i'm mainly looking for a mount that will make exhaust routing simple.
I will be using the dirty dingo slider mounts on the late 70's big c10 mounts.
ChuckLee is offline   Reply With Quote
Old 11-05-2016, 08:56 PM   #2
ChuckLee
Re: Does the 4l60/4l80 lsx trans mount work for t56?
anyone know if the 4l60/4l80 crossmember also works for the T56 6 speed manual trans? i'm doing this swap the easy way or the hard way if i can't find the right crossmember. i would rather do it the easy way and simply my exhaust routing.
anyone?
chirp...........chirp
Old 11-07-2016, 02:07 PM   #3
sangell
What's the t-56 out of? The one I used is from a 2005 Caddy CTS-V and it is now where close to the mount that I had for the 4L80E that was going to be used. Are you asking about the actual mount or cross member location?
sangell is offline   Reply With Quote
Old 11-07-2016, 08:31 PM   #4
ChuckLee
I think I got it figured out. I just wanted to know if the ls swap trans cross members that had exhaust humps for easier pipe routing would also work with the t56.
