11-04-2016, 02:10 PM | #1 |
3/4 ton stock wheel size?
I am looking at a 72 3/4 ton truck that still has split rims on it and am wondering what size of steel wheel I should be looking for in order to replace them? I want just the stock look, with say a 235/85 tire and want to be able to mount the stock dog dish hubcaps. I guess what I'm asking is what is the stock wheel size? Any help is appreciated!
Dave R. 1972 K20 1972 C20 Highlander 1967 C10 |
11-04-2016, 03:02 PM | #2 |
Re: 3/4 ton stock wheel size?
Should have 16", at least that's what my step dads '71 came stock with.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
11-04-2016, 03:36 PM | #3 |
My 70 C20 came with 16.5 rims (not sure of the width) and a tire size of 9.50 16.5 I have changed them out to a 16" rim as the 16.5 rims are not the safest if you loose tire pressure. Something about the angle of the bead that in the event of a pressure loss the tire will come off the rim much easier than the newer rims.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-04-2016, 06:11 PM | #4 |
A lot of guys replace them with Ford E250 wheels. There is a few threads out there that will give you the accuride part number if you go new.
Etrailer.com has new ones also, should be plenty in the bone yards. And they'll accept our hubcaps too. |
11-05-2016, 08:10 AM | #5 |
Thanks for the replies so far.....does anybody know the proper width if using a 235 85 16 tire? Thanks.
11-05-2016, 10:29 AM | #6 |
20' Daredevil (Ret)
11-05-2016, 03:46 PM | #7 |
These are 16x6.5 off of an '88 Suburban 3/4 ton wrapped with 245/75R16 tires. Using the hubcaps until I can get the correct ones for my '72
