Rear marker lights. Step side same for a dually?
I'm looking for rear dually marker lenses and not finding much. Only thing I'm really finding are early 73-80 step side lenses. Comparing pictures they look the same but does anyone know if they will fit? Would like to replace both red and amber lenses with deluxe trim.
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
#2 | |
Re: Rear marker lights. Step side same for a dually?
![]() Join Date: Jun 2009
I disagree on them being the same. They will fit and work but on the lenses I have seen the pattern differs from dually to stepside.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Thanks SCOTI for the reply that's what I was hoping for.
1774btcrew what do u mean the actual lens pattern is different or the pattern of the lens is different like shape? Know where I can find some to see the differences?
They are shaped exactly the same. The pattern on the lenses are different. Duallies have the same pattern as the front marker lens on the fenders
#7 | |
They are not the same marker light but they do fit the location & work as a replacement if your old units are faded, cracked, or missing. I swapped them onto my 89CC dually w/o issue.
Next!
The GM part numbers for the dually lenses are 339885-86-87-88
And yes the other ones WILL work
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
Correct. Each will work but the lenses design are different
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
