11-04-2016, 02:35 PM | #1 |
82 silverado ignition rake
Has any one ever replaced one of these i have the column torn down to where i was able to pull out the broken one i just dnt know how to go about and replacing it here is the part if it would help dorman part number 83211
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good " |
11-04-2016, 04:08 PM | #2 |
Addicted to Rust
Re: 82 silverado ignition rake
If both halves of the rack are broken, its nearly a full on disassembly. You will need a pivot pin remover. Be sure to tighten the bolts that hold the lower knuckle on while you are in there. If only the plastic upper gear is broken replace it only the lower is harder to do and usually not broken.
Decent write up here although not a truck column http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
11-04-2016, 07:39 PM | #3 |
Its the actual rack the long gray part snapped where it connects to the rod that goea down to the ignition switch (under the column)
