![]() Join Date: May 2016
WTB clutch linkage.
I have the clutch pedal. I need everything else. I have the fork. But I need everything in between. For a Chevy 350. Thanks.
![]() ![]() Join Date: Jan 2015
Re: WTB clutch linkage.
I should have this off a 72 C/30 with a 350 I'll get pics tomorrow morning if interested thanks Jeff
![]() Join Date: Sep 2007
i hasve the z bar. the ball that screws into the block and the rod that goes thru the firewall to the z bar for the v8
50.00 plus ship
1967custom |
Yeah let me know Jeff. I'm interested in getting the whole thing if I can.
I should've mentioned it's 2 Wheel Dr. I don't know if it makes a difference.
You mentioned the parts are off a C 30 I have a C 10 are the clutch linkage set up the same?
In case ypu were interested..
1967custom |
Here is a pic of the parts not sure if there's a difference in a C/30 & C/10 but it was a 350 truck $50.00 shipped let me know thanks Jeff ps the grease is free lol
I will take it. Hopefully it fits. Please P.m. me. PayPal information. And I will send payment. And shipping address. Thank you.
Pm sent
Payment will be sent out first thing Monday morning. Thank you.
#13 |
![]() Join Date: Mar 2012
thats a 4wd setup, 2wd has a straight rod
#14 |
Will it still work? Or will I have to get a different rod?
#15 |
not sure, theres alot of questions on this, i thought 2wd had the straight rod. frames are different i know, z-bar might be longer or shorter?
#16 |
I guess I better get into this more. I would like to get the parts that are meant to fit.
#17 |
do a search on here, you'll get answers, good luck
#18 |
#19 |
#20 |
upper, maybe different applications but what you have is what i have on my 69 4x4
#21 |
Thank you for the links. Very helpful. I think it will work. The 30 series cab and frame seem to be the same. As far as the cab to the front of the frame. And it was out of the 350. So I think I will still go ahead and get it. Thank you for all the help.
#22 | |
Also, from what I have seen in my research is that there are variations in the Zbar and mount points based on engine and frame. It looks like the upper and lower rods were always the same. again, based on what I have seen. good luck |
#23 |
I got the clutch linkage from Jeff's bowties. It will work just fine. Thank you for your information.
