laying low
![]() Join Date: Mar 2001
No replacement parts for vintage air units?
I read someone's post recently that said vintage air does not sell replacement parts for their systems. Is that right? You spend a grand or more for their system and some part fails, what will you do?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: No replacement parts for vintage air units?
Summit racing sells individual parts for VA. Get the part numbers from VA's website. I had to replace a hose that fell on my alternator pulley and bought a hose kit and had to buy one additional part.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
I could not get the actuators that opened the heater door on my V/A system and because the build took so long it was out of warranty ,I had to but a complete new system to get the heat to work .I now have a spare junk kit worth nothing .I will probably never use V/A again.
#4 | |
I used to work for Classic Auto Air. They sold individual parts. I remember putting in a couple of orders myself for customers. Just needed the part number. Of course this was more than a decade ago. They may have changed since then
#6 | |
![]() Join Date: Jul 2015
Thanks John |
I have everything that was removed from my truck .
Re: No replacement parts for vintage air units? I used to work for Classic Auto Air. They sold individual parts. I remember putting in a couple of orders myself for customers. Just needed the part number. Of course this was more than a decade ago. They may have changed since then i actually dealt with them on friday and bought parts for a 64-6 that had been lost on a long term build. no problems here!!!!!
for my yoke is easy and my burdens light. J.C. matthew 11:30 Last edited by fergi62; 11-05-2016 at 11:06 PM. Reason: dialogue |
Old member
Classic auto group AC air all the way much better unit's than V/A in my opinion.
I have used them 2 times and both times they where great to deal with. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Vintage Air offers a full line of replacement parts that can be ordered separately to service their full line of Sure Fit and Universal Kits. However some components may need to be replaced at the factory so the part may need to be sent in for service. If there are any questions on this please contact Vintage Air Sales or Technical Departments at 800-862-6658, Thank you.
Never a failure, Always a lesson! 1968 Chevy SWB Fleetside ECE 4/6 327/350 1987 Chevy V20 Scottsdale 4X4 350/400 4.10 1987 Chevy Custom Deluxe SWB 305/7004R4 1991 Suburban Silverado V1500 4X4 350/700R4 2015 Chevy Crew Cab SWB (Daily Driver) 5.3 |
I had to replace the heater valve/switch on my VA. Called up VA and they shipped out a replacement. No complaints here.
The tech dept at V/A told me the actuators never went out and would not let me order parts .They told my shop the same thing ,wont buy another unit from them.
#13 |
Local Detroit diesel nut!
![]() Join Date: Apr 2008
I won't be using a Vintage air setup on my '69 GMC after the unit I had on my '71 GMC. The system never worked right, A/C never really got cold. They blamed it on my compressor, which they claimed was a variable displacement, which it wasn't. After I proved them wrong, they said it wasn't evacuated properly, which it was, I did it myself with my $5000 Robinair A/C machine. Than they said I didn't charge it with the correct amount of refrigerant, and on and on and on. Finally got a hint from someone to adjust the cutout switch on the box and than they system worked 'better' but still not right. After that ordeal, never again will I use Vintage Air on anything.
MIke
Nothing cool anymore, I am old and boring.... |
#14 | |
#15 |
![]() Join Date: Jan 2002
thanks for the heads up on vintage air !!!! i was just thinking about buying 2 units for project trucks !! these companies need to realize "the customer is first priority " or there company wont stay in business !!! thanks again!!!!!!!!!!!!!
#16 |
I'm not saying anybody did anything wrong but I have installed several Vintage Air kits in customers and my own vehicles and they work.
IMO a company that has been around for over 40 years must have a good product that works, that they stand behind and excellent customer service. However there will always be some people that don't like certain companies, for example I'll never buy a Ford. Not because Ford is bad I just don't like them.
#17 |
My current V/A system works fine but having to buy 2 kits because V/A would not help stinks .Both kits were installed by competent shops .the air part worked fine on the first one ,the heat blend door would not open because the actuator was bad and V/A said they NEVER went bad and would not help at all.
#18 |
![]() Join Date: May 2013
nostalgia air , in okala florida is a good source also , friendly , knowledgeable , affordable , and they sell parts , to full systems
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#19 |
What pissed me off the most about Vintage Air is when I did have a problem with it, they blamed everything else but their product. They even questioned me and stated I should of had it installed by a professional repair shop. After I offered to send them a copy of my business license ( I run an auto repair shop, been here 23 years), my ASE master tech and MACS A/C certificates, they calmed down a bit but still were not able to help me. They kept blaming the compressor which was the same displacement as their Sanden unit, basically I had an OE version of the aftermarket Sanden. Luckily I was able to make my system work 'acceptably' well with a tweak of the cutout switch! The rest of their system was great and installed well I will say, no complaints there!!!
Good luck, I know I won't give them a 2nd chance Mike
#20 |
Well guys ,thanks to this thread V/A is going to pick up my kit and see what the problem was and hopefully they will agree that the blend door would not open.
#21 |
I put VA in 3 vehicles and will put it in my 68. no problems with them
#22 |
here is a response i got when i asked them about individual parts:
Which individual parts do you seek out? If you are looking for the kit minus a compressor and bracket, we can do that. If you are wanting something taken out of the evaporator kit, we cannot do that. We can exchange the controls in most cases but not individual pieces. Give me a call if you would like further information or to let me know what parts you would like to delete from kit. Thank you, Roy Arreguin Sales Vintage Air, Inc. 1.800.862.6658 Ext 108 www.vintageair.com |
