Old 11-05-2016, 10:44 PM   #1
jcramsey
jcramsey's Avatar
Lowering options for a 62 c20
Just picked up a 62 c20 with a service bed and I'm trying to work out a plan to get it a lot lower. Anyone have any experience bagging one of these trucks? Don't want to get into frame modification up front just yet so I know that will limit how low I can go, so just wondering what kind of stance could I expect from removing the torsion bars, cupping the lower control arms and mounting some bags? Drop spindles would be nice but if they even make them for 60-62 I'm pretty sure they are spendy. I would like to keep 8 lug just for the uniqueness, but I'm thinking would I be better suited swapping to a c10 rearend and front cross member. Parts are readily available and cheaper, and I imagine the gearing in that 8 lug axle will be good for pulling stumps but not for highway speeds.
I did let off on the torsion bars just to see where that would get me. Have a little more to go before I'm sitting on the bumps but I don't think cranking them all the way down will be anywhere near how low I want to go.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 11-06-2016, 11:04 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Lowering options for a 62 c20
Swap in some 67-72/73-87 ball joints and drop spindles. Keep the torsion bars. Your contradicting yourself by not modifying the front end if you want to go that low but you're going to have to modify it if bagging.
72chevytrucks.com/vboard/showthread.php?t=721782
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-06-2016, 02:10 PM   #3
jcramsey
jcramsey's Avatar
Thanks LV...food for thought!
The Egg Hauler
The Government Mule
Old 11-06-2016, 09:22 PM   #4
Brad54
Brad54's Avatar
Not really seeing how you can swap any ball joints with the stock lower control arms... not without a bunch of fabrication.
Any more info on that?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-06-2016, 09:57 PM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
-Brad
Plenty of threads on how to do it. Its simple. The easiest way however is the Early Classic C20 drop spindles.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-07-2016, 12:35 AM   #6
Brad54
Brad54's Avatar
I've seen countless threads on swapping the cross members and lower control arms, but after a pretty long check, I don't see any threads on swapping later ball joints into '60-'62 lower control arms and keeping the torsion bars.
The '60-'62 lower ball joint itself is the end of the control arm--there's no control arm for the ball joint to bolt INTO, because it IS the end of the control arm, unlike later control arms.
-Brad
Old 11-09-2016, 11:45 AM   #7
jcramsey
jcramsey's Avatar
I let off the torsion bars as far as they would go just to see where that would get me. This is sitting on the bumps right now. Obviously probably not very drivable but I just wanted to see where it would get me. I like the direction its headed, but I definitely wanna go lower.
I did come across a build where from what I can tell it looks like the plated the bottom of the 62 control arm and sectioned some out of where the upper bag mount goes. Other than this it looks like he Z'ed the frame a couple inches, but he was way low. I'm wondering if I forgo the Z'ed frame and just section out the upper mounts, will that get me pretty low?
The Egg Hauler
The Government Mule
Old 11-09-2016, 01:00 PM   #8
LVPhotos
LVPhotos's Avatar
There are several ways for ball joint. 1 is a flat plate to help bolt on newer torsion bar truck joints (4x4). 2 a tube style for press in.
Pic of my PB arms for press in 72-88 ball joints for reference. This can be done same way on stock arms. Just make sure the tube is big enough. Find your spindles and appropriate ball joint and go from there, and lower tires. How low is low? Mine was 9" at cab just torsion bars.
