Old 11-06-2016, 07:58 PM   #1
custom10nut
custom10nut's Avatar
Factory bed wood
What type of wood was used from the factory for the bed wood in our trucks?
Is it a sort of Pine?
I know people use just about every kind of wood you could think of, but I want to cut and mill my own, for no other Eason than I can say "I did it myself".
I'm looking at yellow pine, soaked down with Boiled Linseed Oil.
I love the way it looks as it ages, and it would outlive me in the long run. My original bed has lasted 46+ years and still looks decent, but I'm fixin to relocate my gas tank, and move on to finishing the body work, so it's time to replace the wood.
custom10nut is offline   Reply With Quote
Old 11-06-2016, 08:12 PM   #2
LongBox
Re: Factory bed wood
I cannot answer your question, but the individual boards in the wood bed in the 71 longbed I owned back in the day curled. The climate where I lived was fairly hot and dry. I guess my point is that either they chose the wrong species of wood, or else they did not treat and finish it correctly.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 11-06-2016, 08:53 PM   #3
custom10nut
Mine became a mushroom farm underneath. When I bought the truck 24 years ago, the wood was solid, so I thought I was doing a good thing by treating it with marine grade varnish. Bad. The top stayed nice, but it rotted from the bottom.
I figure that soaking the boards in the BLO, that they'll be permeated and moisture won't have a chance to get in.
I'm also looking into adding a green dye to the BLO, since my truck color is Medium Olive, o mimic the way they did it from the factory(when they painted the wood and strips body color).
Old 11-06-2016, 09:05 PM   #4
davepl
davepl's Avatar
I think it was pine, but am not 100% sure. I do know they were painted body color, not stained and varnished like we all do these days!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-06-2016, 09:15 PM   #5
custom10nut
I thought so.
I thought about painting the wood body color, but I would also like have some of the woodgrain visible
Old 11-07-2016, 10:07 AM   #6
old51sedan
old51sedan's Avatar
I believe the wood was pine from the factory, it along with the strips were all painted the same color as the body. If you get an original Boucher with a picture of a wood box you can see it.
old51sedan is offline   Reply With Quote
Old 11-07-2016, 07:30 PM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
If it was pine, it was the hardest clear pine I ever saw.
Tom Vogel is offline   Reply With Quote
Old 11-07-2016, 07:35 PM   #8
OregonNed
OregonNed's Avatar
Southern Yellow Pine, I believe?
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 11-07-2016, 07:51 PM   #9
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Originally pine but if you treat yours with Coppertox you will have your green color and the best wood preservative on the planet.
CaptRMW is offline   Reply With Quote
Old 11-07-2016, 11:28 PM   #10
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Bed wood and strips were painted black up until 1967, 68 and after were painted body color.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 11-08-2016, 09:59 AM   #11
old51sedan
old51sedan's Avatar
Smile Re: Factory bed wood
I posted yesterday that they were pine & painted body color from the factory. I just bought a 69 step side this spring & the reason I wanted a 69 was because I had bought one new in the fall of 1968. It had a pine wood floor and the whole thing, strips and all were painted same as the truck. They may have been painted black before that, I don't know. The 69 I have now has the original floor (needs replaced) and it is painted same color as the body. Hope this helps.
