Old 11-06-2016, 10:13 PM   #1
JohnKimble
'85 350 no fast idle?
Hello,
First off let me start by saying I have an '85 with a 350 and California emissions package Now that the weather is getting colder I've noticed my choke remains open, even after leaving it overnight in the cold. It still starts up fine, but does not idle any faster when cold vs. warm. Did this truck come with a fast idle cam? If so, should I be able to kick it down with a blip of the throttle after the initial cold start?
Thanks!
JohnKimble is offline   Reply With Quote
Old 11-07-2016, 12:55 AM   #2
geezer#99
geezer#99's Avatar
Re: '85 350 no fast idle?
Assuming it's a quadrajet with an electric choke, just richen the choke setting. Rotate the black cap ccw. There's three screws that hold it on. There's a high idle screw under the choke pull off pot. Hard to see but just needs a phillips to turn it.
Kicking it down depends on how rich it is and how quick it warms up.
Old 11-07-2016, 01:08 AM   #3
JohnKimble
Thank you, I will attempt this tomorrow.
Old 11-07-2016, 04:21 PM   #4
JohnKimble
I just tried to rotate my choke cap ccw. It won't do anything. I can't close the choke plate manually, the linkage is firm and refuses to budge. Any suggestions?
Old 11-07-2016, 04:53 PM   #5
geezer#99
geezer#99's Avatar
Take a pic!!
Is it screwed or riveted on?
Old 11-07-2016, 04:55 PM   #6
JohnKimble
Okay I got the choke plate to close and cap adjusted correctly. Onto the fast idle issue:
I turn the truck on: Fast idle occurs. I blip the gas. Fast idle continues.
I manually press down on the fast idle cam and it kicks it down a step or two. Suggestions?
Old 11-07-2016, 05:09 PM   #7
geezer#99
geezer#99's Avatar
Turn the cap again to lean it down. It's a compromise. You gotta experiment to find that sweet spot. You mighta gone too rich.
It's all a juggling act!!
I'm assuming this is an electric choke??
Old 11-07-2016, 05:30 PM   #8
JohnKimble
Yes it's an electric choke. So I backed out the fast idle screw a little and cleaned it up. I blip the throttle and it kicks down! I'm sure the neighbors have been tired of hearing that thing idling so high at 4am. Thanks for your help #99!
Fast idle and choke fixed!
