Window Flange Rust
So I took the rear window out of my 72 (large rear window) and the metal flange that the the gasket goes over is in pretty rough shape. There is a pretty good size spot right above the gasket on the cab that had about 3/8" of bondo covering a dent. Well the water was leaking into the gasket from the dent and has done a number on the metal flange. Does anyone have any tips for repairing this (both inside and outer pieces of the flange need to be repaired/replaced)?
#2 | ||
"I ain't nobody, dork."
Re: Window Flange Rust
Sounds like it needs to be cut out and a new one welded in from a donor truck as there is no patch panel made for this.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
