Old 11-08-2016, 12:52 AM   #1
mosel70
1970 Chevy C10 Centerlink Backwards?
Is my center link installed backwards?
I installed a CPP front disc brake conversion kit, new CPP upper and lower control arms, and new a endlink sway bar. Also installed new disc/drum master cylinder and booster from Summit for power brakes and a power steering conversion kit. Tie rods are '73-'87 style from CPP.
Before and after front end alignment by a good alignment shop in Las Vegas, it still vibrates a lot when turning, especially at low speeds. Something I never had with manual brakes/steering. It also over reacts when trying to do normal steering, really annoying and borderline dangerous.
Any help would be great!
mosel70 is offline   Reply With Quote
Old 11-08-2016, 06:14 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1970 Chevy C10 Centerlink Backwards?
YES it's on backwards.
The inner tie rods should connect on the back side of the centerlink with the nuts on the front side.
Take it off and swap it end for end.
Keith
Convert to disc brakes.
Old 11-08-2016, 07:18 AM   #3
GR8-68
GR8-68's Avatar
yep, didn't know you could but now we do. thanks for posting
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 11-08-2016, 09:09 AM   #4
jjzepplin
jjzepplin's Avatar
Stunned. And a little worried about your alignment shop. Going out to check mine now as I too didn't know this could be done.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-08-2016, 11:38 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
"Good alignment shop"...
They should have caught this. I bet it will drive a lot better once you swap it around correctly.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-11-2016, 07:34 PM   #6
Dunenutt
Newbee
Dunenutt's Avatar
I did that once! A lonnnnnnng time ago. Steers really funky, LOL.
Dunenutt is offline   Reply With Quote
Old 11-12-2016, 12:59 AM   #7
mosel70
Yes, that did it. Swapped it end to end and placed nuts on forward side. What a difference in driving. It no longer over reacts. It takes quite some trial and error figuring out what sequence to reconnect it all. It ended up being a bit higher and closer to the cross member. lolife99, many thanks for the help!
