Old 11-08-2016, 01:38 AM   #1
Racur96
Pros of front crossmember swap?
Hi guys, I've got a 63 c10 swb, what's so good about the front crossmember swap 73-87? I want to stay 6 lug but I have found the disc brake spindle kit & ps conversion kit for my own 63 front end & I'll be going with air ride. Is the front crossmember just a cheaper alternative or does it have specific advantages?
Racur96 is offline   Reply With Quote
Old 11-08-2016, 07:46 AM   #2
PGSigns
PGSigns's Avatar
Re: Pros of front crossmember swap?
Couple of things. They are on rubber bushings, balljoints and tie rods are a little bigger, the ubolts for the lower cross shaft are bigger, the bolts for the attachment of the upper arm are longer making it easier to align, you can still find a drag link if you need one and the idler arm is bigger. And they are everywhere in the junk yards around here.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-08-2016, 09:18 AM   #3
64shortbox
64shortbox's Avatar
As PGSigns said,
Plus you can assemble/rebuild your entire front suspension while still being able to Drive your Truck! That way if there're any delays in your plans (this happens to me a LOT) you're still able to use your truck. And don't forget about grabbing a 1 1/4" front sway bar off a one ton truck while you're at it. I built a little stand with some scrap metal just big enough to slide my floor jack under and just jacked everything into place and bolted it up when I was ready. I used metal but you can just as easily build one out of some scrap 2x4's.
64shortbox is offline   Reply With Quote
Old 11-09-2016, 05:30 PM   #4
forestb
forestb's Avatar
Correct me if I am wrong but I don't think you have to use the entire front cross member. I think you can drill out the holes for the u bolts so that they fit the 73-87 u bolts and then bolt on the 73-87 upper and lower control arms. I have not done this before but it has been discussed in other threads. Doing it this way will allow you to keep your engine in the truck while you do the job and you will not need to drill new holes in the frame.
forestb is offline   Reply With Quote
Old 11-09-2016, 10:31 PM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
We just did the same with a 75 C10 front end. 2 hours and we were done start to finish. Roll it out, drill a few holes and roll it under and bolt together. Forget all that controll arm swapping and ball joint swapping!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-10-2016, 12:24 AM   #6
Captainfab
60-66 Nut
It all depends what you want in the end. As said above you can make the swap in a few hours (with engine removed) as long as you don't mind driving it at stock height and with stock parts. Then you can replace worn parts when you have time. But if you are one that has to have everything new and or want dropped spindles and springs, then just tear apart your original suspension down to the crossmember and start rebuilding from there. Of course you can also rebuild the entire '73-'87 suspension at your leisure and then swap the complete assembly in a weekend.
