11-08-2016, 12:58 PM | #1 |
Input: Holley Sniper EFI Vs FI Tech
I'm in the market for an EFI retrofit kit. FI Tech has been around for a couple years, with good initial reviews but the support has apparently gone downhill, plus the fuel system (Fuel Command Center) has had mixed reviews.
http://fitechefi.com/products/40003/ Holley's Sniper EFI system was recently released. $1000 for the EFI system, or $1,250 with the in-line fuel pump. Bronze colored version, love this one: https://www.holley.com/products/fuel...parts/550-516K There does not seem to be any reviews on the Holley system so far, but I'm curious if anyone sees any weak points of the Holley setup including the fuel system. I plan to use the current in-cab fuel tank, and I expect I'll have to run a return back to it, or employ the stock return line if there is one. Long term, I may install a rear fuel tank with an in-tank pump. Thanks for any feedback.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. Last edited by Ekliptix; 11-08-2016 at 01:15 PM. |
11-08-2016, 01:10 PM | #2 | |
Re: Input: Holley Sniper EFI Vs FI Tech
Can't speak for the Holley setup, but they usually do stuff right.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
11-08-2016, 01:17 PM | #3 |
Am I correct in saying the potential for 'sloshing' and temporarily losing fuel pressure with an in-cab tank applies to both mechanical fuel pump, or an in-line electric pump? It's not a problem I'm currently suffering from, so I don't anticipate my cornering will increase after the EFI kit.
11-08-2016, 01:24 PM | #4 | |
I've been kicking around modifying a stock pickup to work with the Holley hydra mat to hopefully eliminate the issue. Don't know how well it would work though. The fuel reservoir that FITech uses fixes the issue, but I keep reading about issues with those. Edelbrock has had a similar fuel reservoir out for years, but I haven't been able to find whole lot of info from people who have it.
11-08-2016, 01:28 PM | #5 |
You can tee into the suction side of the pump for the return
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-08-2016, 01:56 PM | #6 | ||
I purchased FITech's 30002 system. As objective as I can be:
As for stock in-cab tank slosh issues: so far no issues with mine down to the 1/8 fuel level but I would expect fuel pick up issues with a car or truck that is hot rodding and cornering hard. I am using my stock tank temporarily til i build my flatbed then I'll install a proper 40 gallon efi tank under the bed.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's Last edited by snj8198; 11-08-2016 at 02:18 PM. Reason: added pics |
11-08-2016, 02:31 PM | #7 | |
I keep going back and forth on what I want to do with my truck. I like the idea of fuel injection for all of the obvious reasons. The biggest one is to auto compensate for when the AC compressor kicks in. I already have a nicely re-plumbed fuel system in the truck with Earl's hose and AN fittings throughout. Maybe I read too much, but I have heard of a lot of issues with stock tanks and external fuel pumps, fuel starvation below half tank, etc. My truck is set up to drive aggressively. Its in no way a pro-touring truck, but it corners well and I like to drive it hard.I don't want to be constantly worried about losing fuel. Things like that bother my OCD----even if it isn't real it will stress me out. I don't want a new tank, I like the nostalgia of the original in cab tank. Plus I don't want to lose the space under the bed, and I don't want to deal with the hole from the old filler or setting up a new filler that doesn't also drive me nuts. Yeah----I'm hard to please.
11-08-2016, 05:06 PM | #8 |
There were a couple of other FI Tech install and review threads on this site and they were pretty favorable. Do a search and I'm sure they'll come up.
11-08-2016, 05:41 PM | #9 |
I've read them here, and the reviews on other sites too. I would have gone with FI Tech, but with the Holley option available at a good price now, I'm leaning hard to Holley for the reputation, experience and support infrastructure.
11-08-2016, 06:15 PM | #10 |
laying low
There are several FI units on the market. Atomic efi, msd and others. I ran across an ad for Fuel Tech just the other day. I hadn't heard of that one. It looks much like FI tech and holleys units.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-08-2016, 06:54 PM | #11 |
From what I know, FI Tech has been the only option in the $1000 price range for a couple years. MSD, Atomic EFI, etc are all more expensive, again, from what I know. Holley is the first big-name option at the $1,000 price point.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
11-08-2016, 06:56 PM | #12 |
Thats true. The others are significantly more costly. At 2X the cost of a good carb, I can feel ok buying FI. At 6X-----I have a hard time with it.
11-08-2016, 10:23 PM | #13 |
Can't give any info on the systems, but I have some experience as far as running the stock fuel tank with efi. I had a 68 with a TBI on a big block, I used the stock sender to feed a Holley pump under the cab and never had a problem with fuel starvation. I would fill up around 1/8 tank usually. I drove it like a hot rod.
My Cadillac is TBI, it has a large flat fuel tank and I had to sump it, it would suck air at anything less than 1/2 on normal tuna boat type driving. The shape of the tank makes a huge difference.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
11-08-2016, 10:47 PM | #14 |
Moderator
I'd say it's a coin toss at this point, but FiTech has been on the learning curve for awhile, whereas Holley is nowhere to be found yet. I have some insider information from Comp Cams (Holley) that they just aren't staffed to handle the new product at all...or any new products for that matter. It kind of shows if you look at the lack of marketing they did with Sniper. FiTech support has not been bad for me. They are busy, but available and mostly helpful. I have some thoughts on the last couple pages of my "Popeye" build linked in my sig. Fuel concerns are going to be the same for any FI system. You need 58psi at the rail, reliably, period. Anything you do will need a return.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-08-2016, 11:12 PM | #15 |
For whatever it's worth, I just ordered the FiTech Go Street setup. I went back and forth on the Holley or the fancier FiTechs, but ultimately liked the $795 price point, didn't see myself using timing control, and liked the idea of going with something that'd been around a while.
I also emailed FiTech a technical question on a Sunday afternoon and heard back that night. They were super helpful... that sort of pushed me over the edge to them. I am putting in a Boyd's tank with the Aeromotive stealth pump and plumbing the whole thing with AN so my fuel system should hopefully be very solid. I thought the FCC seemed like a hack, was worried about loud inline pumps, and just wanted to get rid of the gas in the cab. I probably won't get to do the install until December when I have some time off so more to come.
1969 C10 SWB Stepside, 350, TH350, FiTech Go Street Fuel Injection |
11-09-2016, 10:05 AM | #16 |
11-09-2016, 10:12 AM | #17 |
I installed the Holley terminator using the stick tank. The 72 has a fuel return in the sending unit that has worked great had a concern about it only being1/4 and they wanted a 3/8 for there system. Have not had any fuel starvation issues so far and ran it down to less than a 1/8 of a tank. Check out the Holley forum people are starting to post the sniper installation issues and reviews on it. Only thing that I can suggest is to use a single plane manifold or be prepared to use a spacer.
Posted via Mobile Device |
11-09-2016, 01:40 PM | #18 | |
PITbut
Does that system handle boost?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
11-09-2016, 02:16 PM | #19 |
11-09-2016, 02:20 PM | #20 |
Holley tech support has been excellent 45 minute hold time but they were very helpful and patient. Used them twice
11-09-2016, 03:06 PM | #21 |
11-09-2016, 05:24 PM | #22 |
Old member
I have no dog in this so here is what I can tell you.
The MSD unit sucks if you have a big block with any power! A friend had it installed before the 2016 Hot Rod Power Tour. He went through several hand helds, computers and even the throttle body itself while on the tour. They 'MSD' where there the whole week and not one time did they offer any real help. Except to swap parts. His truck was out in front of their tent every day for 7 days. They never could tell him what was wrong just swap parts that never fixed it. As of last week it's sitting in his garage waiting to have the carb put back on it and trash the EFI unit. They will not replace anymore parts and blame his vehicle for the problems. He is out over $2000.00. Just a word of caution if you have a lot of HP. His is right at 500HP.
11-09-2016, 06:50 PM | #23 |
Found a guy who switched from FI Tech on his Chevelle to the Holley Sniper: http://www.chevelles.com/forums/89-e...ed-fitech.html
He likes it, but didn't really say what the reason for ditching the FI Tech was except that the performance was inconsistent. He says the Holley seems to require the key partially turned to prime the system before it'll turn over, ever time. May be just hi situation, not everyone's. He says the Holley learns faster. And FYI, the gold color unit from Holley is not available yet. I called them after ~20 minutes on hold and spoke with "Scooter" at Holley.
02-26-2017, 03:12 PM | #24 |
Ttt. So which is best? I know the differences in the time each system has been out has lot to do with it. FiTech is easily available now and Holley has about 1 month delay.
02-26-2017, 05:01 PM | #25 |
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
