Old 11-08-2016, 04:33 PM   #1
Bullcreek
LQ4 Question
I purchased an LQ4/4L80E combo this weekend. The guy I bought it from said it came out of a 2003 Silverado 2500. The production date of the truck was 11/02. Everything I read online says the 2003 engines in the trucks were drive by wire. This engine is a drive by cable. Has anyone seen this before? From my research it appears the vans were drive by cable until around 2006 but the trucks all changed in 2003. This has me puzzled.
Bullcreek is offline   Reply With Quote
Old 11-08-2016, 05:20 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: LQ4 Question
Someone could have put a different throttle body on it. Or it could have came from a van.
Did it come with the wire harness? If it did, is it a truck or van harness?
95 S_Trucker is offline   Reply With Quote
Old 11-08-2016, 05:24 PM   #3
Bullcreek
Re: LQ4 Question
How do I tell the difference between the truck and van harness? I was told it came from a truck and that he drove it before he pulled it.
Old 11-08-2016, 07:37 PM   #4
ls1nova71
ls1nova71's Avatar
Re: LQ4 Question
A van harness will be a lot longer than a truck one. Also, vans have a bigger fan that is black with more blades than a truck engine. The dipsticks will both be longer and vans use a different, smaller MAF. If it is a 2003 or newer engine, there will be a small hose going from the valve cover to the intake right behind the throttle body, but if its a 2002 or older, that hose will go to the throttle body its self.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-09-2016, 11:05 AM   #5
Bullcreek
Re: LQ4 Question
LS1NOVA71 thanks for the information. The hose goes to the throttle body so it must be a 2002.
