Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 11-10-2016, 08:20 AM   #1
Cape Codder
Cape Codder's Avatar
Adding fog lamps
My daughter has an 08 Silverado 1500 She wrecked the front bumper so when repairing I used the fog lamp ends and bought fog lamps. I don't like cutting into factory wiring and wondered if anyone here has done the upgrade with GM parts and would know what is needed as far as a harness and where it plugs in.
Thanks Bob
Cape Codder is offline   Reply With Quote
Old 11-10-2016, 04:59 PM   #2
6772owner
Gearhead
6772owner's Avatar
Re: Adding fog lamps
Bob,
I have an 08' GMC that I added factory driving lights too. I purchased the GM headlight switch that has the driving light button, it is a direct swap for the non-light version. I then Googled the wiring information and found the single pin out on the underside of the underhood fuse block. I used a GM connector I had laying around for the pin and just shoved it into the location on the fuse box. You have to add the fuse to the box for the system and then route the power wire to both lights. I used the factory ground bolt on each side to ground the lights. Everything has been working fine for me so far, hope this helps.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 11-10-2016, 05:26 PM   #3
Cape Codder
Thanks for the info, So did you pin to the fuse from under the fuse box? I see where the fuse goes. Then the switch is already wired to the fuse?
Old 11-10-2016, 06:54 PM   #4
6772owner
Gearhead
6772owner's Avatar
Yes, you have to use the two release levers to be able to lift the fuse box. I also had to take the base out and unclip some of the wiring looms into the fuse panel to have enough room to work. There is a open spot that the pin goes in and engages the relay I believe. The switch is plug and play, the wiring already exists between the switch and the fuse box. You should get the light on the cluster to turn on when the switch is activated.
Old 11-12-2016, 12:18 AM   #5
Bob B.
I installed fog lights on my '11 Yukon with the GM kit. Replace the headlight switch, connect the harness under the fuse box, that was about it. My truck had the fuse and relay in the fuse box in it already.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 11-14-2016, 05:47 PM   #6
6772owner
Gearhead
6772owner's Avatar
The GM kit was too rich for my blood, $400 for two lights, a switch and a small harness... No thanks, I bought the $20 switch and $35/pair aftermarket lamps on E-Bay and spent a little time making my own harness.
Old 11-14-2016, 07:58 PM   #7
Cape Codder
I bought the bumper ends and aftermarket fog lamps when doing the collision reapair I made the harness for the lights already I just didn't want to start drilling holes in the firewall and tapping into the wiring to add an aftermarket switch and relay. I saw the underhood fuse box ready to go so just needed to know about the harness in the cab. Nice that it is good to go with an updated headlamp switch. I ordered a used one off E Bay already.
Thanks to all for your help. Nice to benefit from someone doing it ahead of you.
Old 12-03-2016, 04:26 PM   #8
Cape Codder
OK I just returned from a week in Vegas with my wife and had a great vacation. The Ebay switch was waiting when I returned. Plugged it in and spent an hr. digging through old wire harness parts looking for the lug that fit the fuse box. Finally found one in my junk trailer on a Caddy steering column. Plugged in wired to my home made light harness and everything works as it should. She is moving to Vermont tomorrow so just got it together in time. Thanks again for the advice I feel better with factory relay,switch and fuse arrangement.
Old 12-06-2016, 10:24 PM   #9
nekkidhillbilly
if you shop around you can find everything for about 85 dollars to do the factory setup
nekkidhillbilly is offline   Reply With Quote
