10-10-2003, 12:01 PM | #1 |
71 DELUX
diameter of rear U-bolts
Anyone know what the rear u-bolt diameter is for a 71 2WD? Probably no different than the diameter on any other trailing arm chevy truck. Gonna have a new pair of U-bolts made and this is the number one question I keep getting asked.
10-10-2003, 12:36 PM | #2 |
I just drilled some holes in a plate for my u-bolts and used a 3/4 inch bit. The size was close so depending on the stock they have it is slightly less than 3/4 inch. Hope this helps
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-10-2003, 12:55 PM | #3 |
71 DELUX
Yeah, when I am talking to these places (the parts stores more than the BIG RIG fabricators) I keep getting asked, "Are they 5/8 or 9/16 inches?" And they are definitely thicker than "normal" so that "close to 3/4" size sounds right.
I can't get a quote over the phone unless I know the right size and I'd rather not run all over town for quotes with my U-bolt in hand. There are several places in town that will make them "while U wait" but the local Napa store is much closer, so I am trying to find out so I can buy a pair from them. Thanks! |
10-10-2003, 02:28 PM | #4 |
Cantankerous Geezer
The napa store won't have them. They have to be manufactured. I bought mine this summer, went into a local truck spring shop, laid the bolt on the counter.
The old guy said: 1/2 ton Chevy pickup. Yes 67-72. Yes. Let me go get them. They were already made, in stock, cost about $15 each. 3/4", I can't recall the width and length. Measure them and find out.
Fred There is no such thing as too much cam...just not enough engine. |
10-10-2003, 03:02 PM | #5 |
Inline 69
go to a 4x4 shop that installs lift kits, http://www.suspensionconnection.com/...tion/to=x.html
