Old 11-10-2016, 12:37 PM   #1
ufbugman
Electric fans
I'm thinking of adding twin electric fans to my 71 has a 327 right now, to help with the A/c... should I remove the water pump fan or leave it there...
ufbugman is offline   Reply With Quote
Old 11-10-2016, 01:00 PM   #2
biketopia
Re: Electric fans
one or the other... Does your current fan have a shroud, the the stock set up when working correctly is enough to cool a big block with AC. What do you have as far as fan, radiator, clutch t-stat set up currently?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 11-10-2016, 01:08 PM   #3
ufbugman
Re: Electric fans
Stock fan, has a shroud,no clutch on fan... works good when truck is moving but when in slow or stopped A/C starts to blow less cold A/C... but when I put it in N give it some gas it blows cold... Just thinks fans would work better. got stuck in traffic alot..
Old 11-10-2016, 01:40 PM   #4
Overdriven
Re: Electric fans
You could just add a pusher fan in front of the radiator and leave the stock fan and shroud in place. I did that to a work truck for the same reason. Eventually I did have the A/C gone over by a good shop who evacuated and then refilled the system which largely negated the need to have the additional pusher fan.
But if you're going through the trouble of adding one fan it's not much more to add a pair with a new shroud. You're already going to be doing the wiring with relay, some sort of fan controller, etc. Throw a little more cash at and you can have a pair of fans with a shroud behind the radiator and get rid of the stock fan and shroud.
Overdriven is offline   Reply With Quote
Old 11-10-2016, 03:38 PM   #5
BugzC10
BugzC10's Avatar
Re: Electric fans
So your not overheating, just the air does not blow as cold at idle? If your not overheating sounds like you need to have your AC checked for freon level.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 11-10-2016, 04:15 PM   #6
ufbugman
Re: Electric fans
A/c is 134 and level is fine..
Old 11-10-2016, 05:37 PM   #7
graymond1967
graymond1967's Avatar
Re: Electric fans
Make sure you upgrade the alternator and wiring when you put the fans in. I didn't at first and the fans didn't work the way I wanted, found out that I was only at 10 amps at idle. Went to a 140amp Powermaster and twin spal fans, 4 gauge wiring across the front and it seems to fix the fax issue.
You may need your rad looked at, or your water pump is not working right. I replaced both and my big block rarely goes over 175, even in traffic. It has air as well.
1967 Chev C10, in the family since 1967, iron head 502, turbo 350, white with red, unrestored.
1970 Acadian SS350, 350 with muncie 4 speed, 12 bolt, best time 13.414 @ 103.72
graymond1967 is offline   Reply With Quote
Old 11-10-2016, 09:14 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Electric fans
First I would check the air flow. Is it only pulling through the radiator are is it going around it, that is the biggest reason your cooling effect isn't working at idle and slow speed.
The air has to be pulled through the radiator to cool not going over under are to the sides.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-11-2016, 06:43 PM   #9
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Re: Electric fans
Consider a flex-fan prior to all the work needed to convert to electric fans (alternator upgrade, wiring, temp sensor, etc). Flex fans are deigned to move more air at idle and flatten out as the RPM's increase.
As for the A/C issue, start by assuring there is ample Freon volume in the system, that the ductwork is opening and closing as it should, and the vacuum switched heater core shut off is working.
suprachrgd82 is offline   Reply With Quote
Old 11-12-2016, 07:38 AM   #10
Boog
laying low
Boog's Avatar
Re: Electric fans
It is completely normal for R134 to cool less at idle speed than at cruising speed. R134 operates better at higher pressure. Even the late model trucks cool less at idle speeds than running down the road. Part of it is air flow through the condenser and part of it is the increased compressor speed.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
