Engine Code Meaning
I have a 1968 GMC C2500, with the 396 engine. The number on the pad is T0306XF. Can someone tell me what that means? There is no VIN number on the pad. I have the build sheet so I know the truck came with a 396. I would like to be able to match the engine to the truck. Thanks!
Re: Engine Code Meaning
XF = 1968, Truck motor, 396ci, 310hp, manual trans, RPO L47, 4bbl, 3/4 ton or 1 ton
CHEVY/GMC VIN DECODERS |
Thank you Bruceman1968. That's a lot of info.; what does the 03 and 06 mean?
Is it common to not have the truck VIN punched on the pad? I know GMC auto products put the VIN on pads for year before 1968.
Trucks didn't get them.
What year they started to I don't recall. I'm thinking 1973 or 74. |
In the mid 1960's, Congress was threatening legislation to curb automobile theft.
GM started stamping partial VIN's on passenger car engines. Trucks were low priority on the thieves agenda at the time so no VIN on truck engines.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Thanks for the info and education.
You can dig deeper and check your casting and casting date codes.
If your block is original your motor's date code should be in november or december. Blocks were usually cast 2 to 3 months before they were used. Look here for that info and where to find it. http://www.mortec.com/ |
