Old 11-11-2016, 07:52 PM   #1
72tutone
Door handle slow
Is it normal for the inside door handle when lifted to fall slowly back down? Or should it snap back down once lifted up?
I lift mine up and it slowly if not doesnt fall all the way down?
Any ideas? Is the latch shot?
72tutone is offline   Reply With Quote
Old 11-11-2016, 08:34 PM   #2
firedemon
Re: Door handle slow
min e snaps back id try taking the door panel off and wd40 the heck out of everything . my door locks were froze solid it took a couple days but theyre working fine now
firedemon is offline   Reply With Quote
Old 11-11-2016, 08:44 PM   #3
72tutone
Do these things go bad? I will pull it a part and take a look.
Old 11-11-2016, 09:11 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Return spring is broken on the remote mechanism. I haven't found a way to repair them.... I would try the lube first like the others have suggested though. Much easier if it works...
LockDoc
Leon
Old 11-11-2016, 09:25 PM   #5
custom10nut
custom10nut's Avatar
I used the Special WD-40 , dry lube rust inhibitor, to lube the door hardware on mine.
Before I did, rolling the driver's side window was a two-handed tasks, now it works fine.
custom10nut is offline   Reply With Quote
Old 11-11-2016, 11:11 PM   #6
rsgt
rsgt's Avatar
I am rebuilding my doors right now. Both of my springs are broken. The new door handle mechanisms are $19.00 each.
rsgt is offline   Reply With Quote
Old 11-11-2016, 11:36 PM   #7
72tutone
Is it the door latch that is the issue? That 50$ or so.
Where is the spring that is broken so I can look on mine
Old 11-11-2016, 11:40 PM   #8
72tutone
Or is it the door control? That i see is 14.95. Is it the spring in this mechanism?
Old 11-12-2016, 12:00 AM   #9
LockDoc
LockDoc's Avatar
Yes, the remote control mechanism as stated in my previous post....
LockDoc
Leon
Old 11-12-2016, 10:14 AM   #10
cdowns
cdowns's Avatar
moving parts like to b cleaned and lubricated every 45years or so to work properly
Old 11-12-2016, 01:08 PM   #11
74baggedbug
I'm having the same problem.. I always have to remind people to push the handle back down
74baggedbug is offline   Reply With Quote
Old 11-12-2016, 01:10 PM   #12
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I'm not sure traditional WD is the way to go here. It's a lubricant to some extent, but it's intent is a cleaner and water displacement. It's good for removing rust and some adhesives. Silicon is probably a better option.
Hadn't seen it called "Remote mechanism" - a.k.a. door latch control. The spring on my LH control was broken and same symptoms.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-16-2016, 11:23 AM   #13
72tutone
Thanks everyone. The control was shot. I ordered a new one and it snaps back quite well. No lubricant was gonna fix the old one.
Old 11-16-2016, 12:06 PM   #14
74baggedbug
Easy to replace?
Old 11-16-2016, 08:28 PM   #15
72tutone
Yes. I already had to doors torn apart as they were getting painted. So putting it back in was no biggie.
