11-11-2016, 11:40 PM | #1 |
Rear Shackle bushing removal 52 Chevy 1/2 ton
Need help on getting the upper shackle bushing out of the rear leaf spring so that I can install the new one on my 52. I was able to get the bottoms out of the leaf spring eye but still no luck on the tops. Anyone have any tips?
11-12-2016, 10:23 AM | #2 |
Hollister Road Co.
Re: Rear Shackle bushing removal 52 Chevy 1/2 ton
They are a press out. You either need to make up a tool or remove the perch and press it out and a new one in.
11-12-2016, 10:47 AM | #3 |
I used largest nut and bolt that fit and sockets to press out.
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
11-12-2016, 11:00 AM | #4 |
Like this but replaced the steel bracket with a Socket.
11-12-2016, 11:40 AM | #5 |
I used a piece of all thread and an old socket for 3 out 4 bushings. The 4th required a body saw, chisel, and lots of cursing.
11-12-2016, 12:41 PM | #6 |
Yup. I think I had one of those. I also used a plumber's torch to heat the bushing.
11-12-2016, 04:19 PM | #7 |
Using the method they suggested works pretty simple and doesn't take a lot of effort of frustration. Trying to beat the out is nothing but frustration. After 40+ years I learned that taking a hack saw blade and sticking it through a bushing and then putting the saw back together lets you cut a slot in the bushing so the pressure is relieved and they usually knock or pull out easily.
11-13-2016, 07:35 PM | #8 |
Thanks guys..
