Old 11-12-2016, 12:09 AM   #1
1970pelle
1970pelle's Avatar
Vacuum Log, Killing time in the garage
I hate a bunch of clutter on an engine and engine compartment. I'm talking about a non-stock Truck, car what ever. Nothing kills a nice clean and detailed engine bay. Like vacuum hoses,wires and the like running and hanging all around.
My truck had a vacuum cluster right behind the carb. Which amplified the problem was the distributor was right there also. And with only one vacuum port in the intake manifold, which is located in back of the carb. The stock vacuum tree, just made the problem center stage.
Its nothing new, I have made them before out of a chunk of brass. All I had today was some square tubing. A little welding and a few holes, tapped the holes out. Now it's still in rough mock up stage, it may not make it on my truck. But one very similar, I'll most likely mount it on the fire wall. It will clean up my intake, to one vacuum line feeding the log.
A little black paint will hide it.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 11-12-2016, 08:22 AM   #2
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: Vacuum Log, Killing time in the garage
thats neato burrito dude
be sure to post more pics when its done
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 11-12-2016, 02:26 PM   #3
S10Fan
Old Heap Driver
I used one of these on my V-8 S-10, best I remember mine came from Harbor Freight and was less than 5 bucks.
https://bossairsuspension.com.au/pro...anifold-block/
Another from Northern......
http://www.northerntool.com/shop/too...8778_200658778
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-12-2016, 02:28 PM   #4
S10Fan
Old Heap Driver
By the way, nothing wrong with home made!
Bryan
