11-12-2016, 02:18 PM | #1 |
steering column lower bearing confusion
Hi. I am rebuilding a steering column that I purchased on eBay. As far as I can tell, it is a 69 to 72 column, because it has the collapsible intermediate shaft. I bought to use in my three on the tree truck, but the column came out of a truck that had a floor shifter I assume, because the column shift lever had been removed. The shift tube, both lower shift levers, etc for the column shift are all still there. Anyway, I am trying to replace the lower bearing, but was having a heck of a time trying to figure out what was in there, as it did not look like my replacement part. As far as I can tell, the bearing that was in there was for a floor shifting column. As the column is originally a column shifter, can I just put the column shift lower bearing back in? I will post a few photos. Thanks very much.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
11-12-2016, 02:20 PM | #2 |
Re: steering column lower bearing confusion
Intermediate shaft.
11-12-2016, 02:22 PM | #3 |
Replacement bearing on the left (column shift style). Bearing that came out of column on the right (floor shift style??)
11-14-2016, 02:39 PM | #4 |
Anybody want to chime in? I'm assuming the column shift style bearing should work, since that is what should have been there originally.
11-15-2016, 01:31 AM | #5 |
It's adjustable at the bottom and not difficult to get to. If the taller/newer one doesn't fit and is too long after tightening everything up, use the smaller one.
