Old 11-12-2016, 03:10 PM   #1
wahl4m
door wont open ??
customer says he bought a 70 chevy truck/been in a garage several yrs /had a hole in garage roof and leaked water on the drivers door BUT window was down a little and water got in door opening{inside door} mechanism and got rusty !! now door wont open -with inner or outer latch !he says he sprayed and oiled latch as best as possible ! still wont open ! any ideas ????? cant see how it will come open w/o cutting door apart ??
wahl4m is offline   Reply With Quote
Old 11-12-2016, 03:49 PM   #2
Deer_hunter_088
Deer_hunter_088's Avatar
Re: door wont open ??
Pb blaster and a couple weeks.
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 11-12-2016, 04:39 PM   #3
Gmc.guy
Gmc.guy's Avatar
I just did this on an '83. Keep oiling and work the outside and inside handles (not rough) and push lock button up and down to work the lube in. If the outside button and levers are stuck and not moving you should be able to take the seat out and remove door panel
-Cody
Gmc.guy is offline   Reply With Quote
Old 11-12-2016, 04:40 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: door wont open ??
Window down. Long screw driver pry on the door latch inside the door while you put pressure on the door with your feet from the inside.
It would help to have some one lay down in the seat to put pressure on it.
If that doesn't work, take fender off and un bolt the hinges to the door.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-12-2016, 04:52 PM   #5
Gmc.guy
Gmc.guy's Avatar
Red face Re: door wont open ??
Bumping the outside handle with a soft mallet will help too. (Not too hard). I'll trade you. I'm trying to get a locking gas cap out today
-Cody
Old 11-12-2016, 05:04 PM   #6
Gmc.guy
Gmc.guy's Avatar
For sure if the window opens like Andy says is the best way
-Cody
Old 11-12-2016, 05:21 PM   #7
zosoppp
Also try putting firm pressure pushing the door in near the latch (not the handle).
My 1970 pass door wouldn't open, the door handle button was broken and pushed in but I was able to get the latch moving a little by pushing hard (no BFH) on the door skin to move the door in a little getting the latch to start working. Then I could open it from the inside, remove the inner panel.
From there I took out the latch itself from the door (three #3/4 phillips screws and a clipped rod inside the door) and worked it with the pb blaster til it was freed up.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 11-12-2016, 05:27 PM   #8
Deer_hunter_088
Pb blaster works wonders and is cheap. Use the heck outa it. Tapping does something to loosen rust. Might have a latch if i can get it outa the door.
1998 S10ZR2
