Old 10-10-2003, 02:08 PM   #1
BigChevMan
My Thoughts Exactly!
BigChevMan's Avatar
help
Ok...I have available to me a 69 c-20 long bed truck for very very very cheap. I have questions regarding the ability to change it to 1/2 ton suspension. I want to do a shortbed conversion. I guess my question would be what is different between the 1/2 ton and 3/4 ton. I was planning on just swapping in a whole crossmember & suspension from a 73-87 truck. Can I still do this? Please help. I don't want to lose this killer deal.
BigChevMan
BigChevMan is offline   Reply With Quote
Old 10-10-2003, 03:25 PM   #2
krue
Designated A-hole!
krue's Avatar
The front crossmember and suspension will bolt up. You only have to enlarge two holes and rerun the brake lines etc.
Does it have leaf or coil rear suspension?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-10-2003, 05:06 PM   #3
bpmcgee
bpmcgee's Avatar
Krue,
I thought that C20s would only come with a leaf rear end. Am I incorrect?
Brian
bpmcgee is offline   Reply With Quote
Old 10-10-2003, 05:11 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Sounds like alot of work to me, good luck.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 10-10-2003, 07:19 PM   #5
ckhd
ckhd's Avatar
There are C20 coil rears. Plenty of them too.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-10-2003, 08:04 PM   #6
BigChevMan
BigChevMan's Avatar
thanks guys...anyone else have any experience with this?
Old 10-10-2003, 11:41 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The more common rear susp on the 3/4 ton is coil, only the one ton and larger had leaf only rear suspentions.
Big Chevy Man, I'm not sure if you've met him, (As I am not sure of your location in the state) but Fine69 is in the middle of doing the 3/4 ton to 1/2 ton suspention swap right now. He would know any problems if any exist.
Old 10-11-2003, 10:46 AM   #8
BigChevMan
BigChevMan's Avatar
I'm in the dayton area. Where is he located at?
Old 10-11-2003, 11:12 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I swapped out the 3/4 ton to 1/2 ton and had no problem's except the rear brake line need's help gettin to the axle.. My truck btw is coil at all four corner's...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-11-2003, 05:25 PM   #10
BigChevMan
BigChevMan's Avatar
How did you do it? Total crossmember swap or just a-arms and spindles and stuff. The truck i'm getting is all coils too. Any more info would be great
Old 10-11-2003, 07:23 PM   #11
Longhorn Man
BigChev, fine69 is located in Urbana, he is a wealth of knowledge.
Old 10-11-2003, 07:32 PM   #12
BigChevMan
BigChevMan's Avatar
thanks...that's not that far away...maybe he'll let me bug him a bit.
Old 10-11-2003, 07:55 PM   #13
Longhorn Man
I know I need to get out there sometime soon. I was supposed to swing by about a month ago but was unable.
Old 10-12-2003, 10:02 AM   #14
FRENCHBLUE72
PROJECT 7DEUCE
I used a stock complete 72 chevy crossmember for the front and just swapped the rear coil's and axle for 1.2 ton stuff..
MEMBER #6377
Project "7DEUCE"
Old 10-12-2003, 12:31 PM   #15
67sss
67sss's Avatar
I did it to a 70 shorty. Someone had put 3/4t stuff in it, so I changed it all back to 1/2t stuff. It was pretty easy cause the motor and tranny were out. Do the front end first the weight of the rearend will help balance the frame and make it easier to work with.
67sss is offline   Reply With Quote
