Old 11-12-2016, 10:04 PM   #1
KyleSeal
KyleSeal's Avatar
I want stock AC, what do I need to know?
I have a local 67-72 parts guy who says he'll sell me all the parts for a stock AC system for $350, granted I need new gaskets and rubber lines, what do I need to know? Do I need a different water pump (I heard you need a small water pump)? I know Ill need to cut the fire wall and dash. Can I use modern fluids in the AC system or will I need to dig up some cans of old refrigerate?
And no, I do not want VintageAir or aftermarket, this is a much more affordable and cost effective way for me to cool off once the trucks done.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 11-12-2016, 10:22 PM   #2
Jocker64
Re: I want stock AC, what do I need to know?
I did exactly that, this is what I did:
I replaced the dash to an a/c dash (I wanted the original vents look)
You'll need the inside and outside housings (boxes)
since I put that stuff used, I bought a new heater core and a/c evaporator
If you want to use new fluids and less weight , I used a sanden compressor
I already had a short water pump but I'll work with a long water pump too, just change the compressor brackets
Need new expansion valve to use R-134
New accumulator and I you want more efficiency, install new condenser
I also change the radiator core, I just wanted the original hose holes
Also there's 2 vacuum activated doors, one in the passenger kick panel and another one inside the cowl
You'll need different a/c dash controls
That should give you more or less an idea!
Good luck
Jocker64 is offline   Reply With Quote
Old 11-12-2016, 10:27 PM   #3
KyleSeal
KyleSeal's Avatar
Do you have a picture of the vacuum activated doors?
Toano VA
Old 11-12-2016, 10:54 PM   #4
Jocker64
The one in the passenger kick panel looks exactly the same but instead of the handle to open and close it it has a vacuum activator
Here is the one in the cowl
Old 11-12-2016, 10:57 PM   #5
KyleSeal
KyleSeal's Avatar
Interesting. I have the cover to the air boxes cut out because of rust (the opening with "door" is still there.. does this effect performance?
Old 11-12-2016, 10:58 PM   #6
KyleSeal
KyleSeal's Avatar
Old 11-12-2016, 11:01 PM   #7
Jocker64
Here are some more pics
Old 11-12-2016, 11:04 PM   #8
Jocker64
The inside door is for cab air recirculating
The outside door (cowl) is for inside or fresh air
Old 11-13-2016, 10:26 AM   #9
F.A.A.benny
If you want to use 134a, its best to use a parallel flow condenser instead of the original tube and fine design that came from the factory. Also want to recalibrate the poa valve. Most guys don't like the poa delete(or update) kits which turn the system into a cycling system. Id get a new heater core but you can flush and pressure check the evaporator to see if it can be used. A new one will cost almost as much as the entire system you plan on buying. Personally, I would not buy an entire system, especially at that price. since quite a few things may need to be replaced. I would buy the ac and heater boxes. Some of the duct work if it was in good shape but take a good look at the distribution duct that bolts directly to the heater box. The blend door is often broken most times and that duct new is over $100. Take a look at the button switch on it as well because that little switch is $40 if you cant locate another used one. You don't need the metal duct as it exactly the same as the one in your heater only system. Check the control panel to make sure the levers aren't broken. You can get repair kits but it can help negotiate a lower price. I wouldn't purchase the drier, condenser, hoses or compressor. I would however take the aluminum hard lines as they fit waaaaay better that the aftermarket but make sure the fittings aren't seized up. New hoses are around $150 or so. You can get a new aluminum A6 replacement compressor to replace the old steel one so you can retain the original brackets and original style hoses. Sure a sanden is less expensive but kind of a wash after you factor in the brackets it needs as well as needing to alter your hose setup.
F.A.A.benny is offline   Reply With Quote
Old 11-13-2016, 10:43 AM   #10
F.A.A.benny
A few pics of some work I've done recentlyand a pic of that duct that I mentioned which is over $100 new.
Old 11-13-2016, 10:59 PM   #11
KyleSeal
KyleSeal's Avatar
what is the last photo of?
Toano VA
Old 11-13-2016, 11:07 PM   #12
F.A.A.benny
Its the distribution duct that bolts directly to the heater box. The door is often broken and new , the duct runs over $100
Old 11-14-2016, 12:42 AM   #13
FirstOwner69
FirstOwner69's Avatar
Unless I missed it, no one above mentioned the differences in the holes in the firewall for A/C vs. heat only. They are significantly different. See post 2 here: http://67-72chevytrucks.com/vboard/s...d.php?t=606420
FirstOwner69 is offline   Reply With Quote
Old 11-14-2016, 12:45 AM   #14
F.A.A.benny
Originally Posted by FirstOwner69 View Post
Unless I missed it, no one above mentioned the differences in the holes in the firewall. They are significantly different. See post 2 here: http://67-72chevytrucks.com/vboard/s...d.php?t=606420
The op mentioned in the first post that he knows he'll have to cut the firewall
Old 11-14-2016, 12:53 AM   #15
FirstOwner69
Oops. I saw he mentioned cutting the dash but missed the firewall comment.
Old 11-14-2016, 04:03 PM   #16
KyleSeal
KyleSeal's Avatar
Also - Im not afraid to cut the firewall and weld, as my father is a good welder and I'm good at making cuts so that I feel comfortable with. Do they make templates?
Also, can I just run heat until I get the AC fully functional? As in, run the heat from the AC system while still obtaining parts.
The offer I have on the table from a local is the whole entire system, inner cab to the radiator - EVERYTHING - granted I'll need new rubber and need to make sure all the parts are functional. But I feel even if I buy them and decide not to go AC I could just sell them.
Toano VA
Old 11-14-2016, 10:41 PM   #17
kaycee
kaycee's Avatar
yes you can run your heat only with a/c setup ,I been doing it for 4 yrs
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 11-15-2016, 01:30 AM   #18
brad_man_72
the boat guy
brad_man_72's Avatar
I can't imagine a factory ac setup being cheaper than any aftermarket setup even if you got it for free. Much less not designed for modern refrigerants. The size. Underhood appearance.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-15-2016, 03:15 AM   #19
F.A.A.benny
Not sure about others but I'm pretty sure I could do factory ac cheaper than VA or CAA
1970, ac system, air conditioning, c10
