11-13-2016, 06:50 PM | #1 |
What is the max drop in the rear?
What is the max drop in the rear with out cutting the bed floor? 70 gmc, swb with leaf springs. I'm looking for 8, I did 3in drop spindles and 3in drop springs, 6 to 5 lug conversion and drum to disc conversion on the front today. I've bought a flip kit for the rear, but I'm out of time for the day to mess with the back. Thank you for any info.
11-15-2016, 09:52 PM | #2 |
Re: What is the max drop in the rear?
I'm I missing something here? Not one response..
11-15-2016, 10:42 PM | #3 |
11-15-2016, 10:46 PM | #4 |
Not yet, I'm trying to see if I can get away with not cutting the bed floor, I bought the flip kit. I don't know if I should get 3in block or the extended spring hanger?
11-15-2016, 11:09 PM | #5 |
Maybe if you measure from the top of the rear differential to the bed floor that should give you some idea on how much drop, but you do need to allow for some suspension travel so it doesn't bottom out every time you go over bumps.
11-16-2016, 10:46 AM | #6 |
Pretty much this. Alternatively, you could just measure from rear end tube to frame minus suspension travel and that is max drop on an unmodified frame with no worry of hitting the bed floor. If you choose to do a c-notch, that will give you about 2.5" more available space to drop. Bottomed out on a c-notch will put the top of the differential just touching the bottom of the bed floor.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
11-16-2016, 04:10 PM | #7 |
I have a 69 short step with leaf springs. I did the DJM flip kit and it dropped the truck 7 1/4". I have almost 2" clearance above axle housing and the 1/4" urethane bump pad that came with the kit.
That is the practical limit IME. It is driveable without any real issues at that level but does bounce off the pad on sharp impacts. My opinion is that 8" is too low without the C notch. 7 is doable.
11-16-2016, 08:19 PM | #8 |
Thank you for the info. I can do the notch, but I was hoping to not have to ge in to the bed floor.
11-16-2016, 09:13 PM | #9 |
I never measured on mine because the frame was the closest interference area, but that would be a deal killer for me. I'm pleased with the look and function of the truck at 7".
11-16-2016, 10:18 PM | #10 |
I may not need 8. I did 6 in the front, so I'm just guessing.
11-16-2016, 11:09 PM | #11 |
I just want the truck to sit level.
11-17-2016, 08:56 AM | #12 |
...then go five in the front.
11-17-2016, 12:05 PM | #13 |
I went 7 in the rear and I did the frame notch and bed raise. I think 5-5.5 inches would be max without mods. My front has 2.5 spindles and 2 inch lowered springs.
11-17-2016, 02:46 PM | #14 |
I've already did the 3in drop spindles and 3in drop springs. I like where the front is sitting.
11-17-2016, 04:14 PM | #15 |
11-17-2016, 04:30 PM | #16 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-17-2016, 04:30 PM | #17 |
11-17-2016, 09:40 PM | #18 | |
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
