Old 11-14-2016, 10:29 AM   #1
Jthomas
Project the Burbs, 51 Suburban build
This post will follow the build progress of my 51 Suburban, bear with me I'm not the greatest with updating posts, but i will try.
A little back story,
I had been look for a good Suburban project for some time, living on the east coast (Pa) everything I found was pretty rough. In 2013 I took a trip out to Bonneville Speedweek with some friends. We flew into Denver to meet up with a friend and drive to Utah. On the trip home we drove back to Colorado Springs a day before our flight out of Denver the next morning. We had a bit of time before we needed to be at the airport, and decided to see a junk yard. That is where I found this Suburban, they actually had a about 5 of them. We also missed our flight, but that is another story!
I made a deal with the yard owner, and told him I would be back for it. About a month later using my trailer and a friends truck the two of us headed for Colorado. We drove straight through. Got out there on a Friday, loaded up Saturday, and headed home Sunday.
I was in the middle of building a shop at my house, so this had to sit and wait for about a year before I really started to work on it.
Here are some pics to get us up to date.
In the yard where I found it
Loaded up and ready for the trip home, took a quick run up Pikes Peak while we were out there.
At home waiting patiently
More to come...
Jthomas is offline   Reply With Quote
Old 11-14-2016, 02:02 PM   #2
iowaboynca
iowaboynca's Avatar
Re: Project the Burbs, 51 Suburban build
Nice grab!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 11-14-2016, 03:28 PM   #3
Advanced Design
Advanced Design's Avatar
Great looking Burb! I am in.
Advanced Design is offline   Reply With Quote
Old 11-14-2016, 04:01 PM   #4
63 & 64 Bowties
and a few others
Great find! Did you get a title with it?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 11-14-2016, 05:47 PM   #5
Jthomas
Thanks! Yes I did.
Old 11-14-2016, 05:56 PM   #6
Jthomas
First order of business was to get the stance right, I picked up a 3" dropped axle from Sid, who is a great guy and I highly recommend his work. I also picked up a full set of Posies 3" springs, I live only a few blocks away from them so that was easy!
New ride height, also the Fulton visor I picked up at the Hershey swap.
Old 11-14-2016, 06:10 PM   #7
Jthomas
Now the real work starts, the plan is a 350, T5, and a 6 lug open rear.
Getting the motor fit up.
Working on motor mounts
Trans mount
Next up giving the steering box some clearance
Brake pedal also needed some clearance, I just shortened it a bit and relocated the hole in the toe board.
I decided to convert the steering arms over to Ford tie rod ends and ditch the old ball and socket style.
Old 11-14-2016, 06:23 PM   #8
Jthomas
Net up was rust repair and metal work, I started with the firewall. Some one had installed a Mustang heater box at some time and hacked up the heater area. I got a piece from a junk yard for a patch.
Also moved the opening for the steering column
Strange hole in the top of the cowl.
All gone
Old 11-14-2016, 06:37 PM   #9
Jthomas
Onto the cowl sides and front floor.
The bottom of these inner replacement panels suck, had to just cut it off and make it.
Out side panel I was lucky enough to find some NOS ones at Hershey, the fit great!
I just decided to patch up the inner structure, the replacement pieces did not look very nice.
On to the drivers side
Old 11-14-2016, 06:47 PM   #10
Jthomas
Now time to take the body off the frame, I did this by myself it was pretty easy. I made a time lapse video of it and if you are on instagram search #projecttheburbs and you will find it along with more pics of the build.
I made a fixture to attach the body to a cart to move it around
Frame goes off to sandblast as I work on more rust
Cleaning up the factory door jam welds
Old 11-14-2016, 06:53 PM   #11
Jthomas
Rear sill removal
Rear corners
Old 11-14-2016, 07:05 PM   #12
Jthomas
Frame and sheet metal back from the sandblasters.
Fresh coat of epoxy primer
Black
It's a roller!
Grill guard I picked up at the Carlisle swap, it will get rechromed
This brings us up to date, I have kinda been burnt out on this project and hope to get back on it this winter. I am currently working on a new project its a 71 Chevy K20 and hope to finish it up soon, just a daily driver for now. Then it will be back on the Burb.
Jeremiah
Old 11-14-2016, 08:10 PM   #13
Advanced Design
Jeremiah, wow, nice metal work! Where did you get the rear corners in post 11?
Old 11-14-2016, 08:38 PM   #14
oldman3
oldman3's Avatar
Doing some very nice work, I'm along for the build...Jim
oldman3 is offline   Reply With Quote
Old 11-14-2016, 08:50 PM   #15
Jthomas
Thanks! They are the ones Jim Carter sells.
I believe this is the guy who makes them.
http://www.wheelwrightrestorations.h...storation.html
Old 11-14-2016, 11:40 PM   #16
youngrodder
youngrodder's Avatar
Great build. I follow you in Instagram. I always chime in on your posts. I go by Greenfield Speedshop.
Looking good.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-15-2016, 01:07 AM   #17
northern 49
northern 49's Avatar
Nice sub! Your metal work looks awesome!
northern 49 is offline   Reply With Quote
Old 11-15-2016, 04:20 AM   #18
lower50's
lower50's's Avatar
Nice work so far. The Fulton visor makes all the difference.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-15-2016, 10:57 AM   #19
Jthomas
Looking good.
Marc
Hey, Marc
I figured there would be some guys from ig on here. I'll have to check out your build thread!
Old 11-15-2016, 10:57 AM   #20
Jthomas
Thanks for the comments guys!
Old 11-16-2016, 06:19 PM   #21
mongocanfly
mongocanfly's Avatar
This is gonna be a nice ride..looking good
