Old 11-14-2016, 12:11 PM   #1
Rogue
Airport Bum
Aluminum brake calipers
Will these gain us any clearance over the single piston OEM?
I'm thinking so, but wondering if anyone has actual experience.
I bet they look pretty too.
https://www.brotherstrucks.com/71-87...tinfo/DPC7187/
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 11-16-2016, 01:01 PM   #2
Rogue
Airport Bum
Re: Aluminum brake calipers
No one using them?
1964 Chevrolet C-10
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Old 11-17-2016, 02:37 AM   #3
andrewmp6
Most run the wilwood d52 dual piston which is close to that.Or they go full big brake kits.
andrewmp6 is offline   Reply With Quote
Old 11-17-2016, 09:07 AM   #4
68Stepbed
68Stepbed's Avatar
I would look for some reviews on them. I'm a little worried about the 2-piece design. If you're only going for looks, they may be ok. If you're after performance, go with a trusted name like Wilwood or Baer. Also, don't underestimate the stock calipers. The only caliper on the market to match the clamping force of a stock D52 truck caliper are the 6 piston Wilwood and Baer units.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-17-2016, 03:31 PM   #5
Rickysnickers
Rickysnickers's Avatar
What does a D52 caliper come off of?
Old 11-17-2016, 07:56 PM   #6
68Stepbed
68Stepbed's Avatar
Pretty much every GM car and truck from 68-mid 90s. The 71-87 1/2 ton trucks have D52 calipers with a 2 15/16" piston. The 3/4 and 1 ton trucks had a larger 3 1/8"(or somewhere close to that) piston.
Wilwood offers a dual piston caliper that has the same dimensions as a standard D52.
Matt
