Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-14-2016, 11:06 PM   #1
chtr65
WTB power steering assist parts
Hello From Pa. Just purchased an original power assist unit for my 65 truck. It's not complete, so I still need a few things. First, I need the fluid reservoir, with mounting bracket and fan belt pulley. Second, I also need the hoses that go from the reservoir to the ram cylinder. Any help would be greatly appreciated. Thanks in advance, Mike
chtr65 is offline   Reply With Quote
Old 11-15-2016, 08:33 AM   #2
southern parts
southern parts's Avatar
Re: WTB power steering assist parts
Sounds like you need a pump and lines.
southern parts is offline   Reply With Quote
Old 11-15-2016, 05:12 PM   #3
chtr65
I'm slightly unfamiliar with this set up, but I believe your terminology is correct. I would like to add this original unit to my truck, perhaps this winter. I'm in the process of doing some research on it currently. But, I have found that most of knowledge has come from this website. The mounting bracket for the pump would also be a must. My 65 has a 283 with powerglide from the factory. Mike
Old 11-15-2016, 11:49 PM   #4
DPowers
DPowers's Avatar
I have this setup, but really dont want to split it up.
DPowers is offline   Reply With Quote
Old 11-16-2016, 06:46 AM   #5
shortstep60
I have a friend that has and old junk yard. Would a pump 0ff of like a 1965 car be the same? He has a lot of 283 cars with that same set up on them its nice to have and old junk yard around because there all about gone. Just trying to help you out.
shortstep60 is offline   Reply With Quote
Old 11-16-2016, 10:17 AM   #6
60-66
60-66's Avatar
If your going 100% stock , heres an original NOS unit ( NFS) that will help you with the correct parts and part numbers.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-16-2016, 05:38 PM   #7
chtr65
DPowers: Thanks for the reply, but I'll pass.
60-66: Please check your pm.
Old 11-16-2016, 06:48 PM   #8
60-66
60-66's Avatar
I replied , had you confused with another member. The pictures are showing up for me in this post. I hope they help. NFS is not for sale , reference only
