Formerly yellow72custom
Too much timing
I was out cruising around in my truck today, and i noiticed a little spark knock while pulling a hill. So, i stopped and backed off the vaccum advance timing (Crane adj. vaccum advance) about 3 degrees.
And wow!! The truck runs alot better with less timing! Throttle response, midrange power, and idle quality all impoved. It even seems that the full throttle power increased too, but i hadn't gotten into the 4bbl in awhile so it's hard to say. I was kinda under the impression that an engine usually runs best with the timing advanced as much as it saftely can be w/o pinging. It usually dosen't ping, i just had filled up with a tank of cheap 91 octane fuel (proably the problem). I am running 11 degrees of base timing on a stock HEI, the Crane blue and silver mech. advance springs, .045" gapped plugs, and 9.7:1 compression with a 204/214 cam. Is there an easier way to figure out the ideal timing for my engine than the "seat of the pants" method?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
67-72 Addict!
This is a nice link. http://www.73-87.com/garage/hei.htm
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Fabricate till you "puke"
the best way is to experiment a bit. I use a timing tape, & try to shoot for a 34-36 degree total, all in around 2800. An additional 10-12 degrees on the vac can should be pretty close. Your comp ratio, coupled with a fairly mild cam may be why it likes a little less timing. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
