CPP or KYB's monotube drop shocks?
Your opinion. front has a 3.5" drop ( 2.5" spindles and 1 inch lowering coil. Before installing the coil springs it was fine. Now any bump and I hit the control arms..Currently running stock length Monroe sensatrac. Thanks!
Diggin The SquareLife
Re: CPP or KYB's monotube drop shocks?
Belltech drop shocks
#3 | |
A 1" drop coil changes the compression distance ~1-2". You should be fine w/stock length shocks. Would it bottom out before? Tell us more about your set-up (wheel & tire size, etc...). Pics would help as well.
255 60 15s tires...with the spindles only was great
Sounds more like the wrong spring (not enough spring-rate for the amount of drop) vs the shock. What age/condition are the current shocks?
Shocks 2 years old...1" springs new mcgaughys
![]() Join Date: Jul 2000
Having used some of their products on my 55 Chevy sedan, I'm done with them. Know that "C" really stands for "Chinese". Maybe CPP = Chinese Product Proliferation.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
I agree with the belltech drop shock. I changed my stock shocks to belltech and the tide is some much smother.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
