Old 11-16-2016, 11:10 AM   #1
Wgesnerjr
Wgesnerjr's Avatar
Headlight Buckets
1985 Custom Deluxe LWB.
I have taken my front end apart and started painting and powder coating. All has gone well and it's going back together and I'm up to the Headlight Buckets.
GM did not think too much of these as they are NOT stamped with a part number or any kind of marking??? I assume they are original as everything else in the front of the truck was. (Grill, core support, valance panel, etc.)
As pictured, these are different in the clocking of the tabs in the back. (see pics, one installed, three waiting) And because this is the one time I did not take a hundred photos before taking it apart, I have no idea which one is high beam vs low beam or Left vs Right?
I do have the Quad Headlight front end so there are 2 with the tabs at 2:00 and 8:00 and 2 with the tabs at 10:00 and 4:00.
Can anyone post some pics of their Quad Headlight set up so I can figure out which one goes where?
Thanks in advance
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 11-16-2016, 11:12 AM   #2
Wgesnerjr
Wgesnerjr's Avatar
Re: Headlight Buckets
Here are the pics
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 11-17-2016, 02:58 PM   #3
Wgesnerjr
Wgesnerjr's Avatar
If someone could take a pic of the back of the core support, that would help too. Just as long as it shows the orientation of the headlight buckets.
Thanks,
Jay
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 11-17-2016, 05:41 PM   #4
DieselSJ
It should be fairly easy - look at where the adjusters are. They really only fit one way.
DieselSJ is offline   Reply With Quote
Old 11-18-2016, 12:17 PM   #5
Wgesnerjr
Wgesnerjr's Avatar
yeah, I did that and figured out left from right. however, each set for left and right have different tabs in the back. (where the plug goes) One at 10:00 and 4:00-the other two at 2:00 and 8:00.
So which one is for the high beam and which one is for the low beam? They fit in each place on the core support and both headlight bulbs fit in each bucket.
It is very UN-like GM to make them different without some kind of reason. The only thing I can think of that makes difference in that area is the headlight plug itself.
I just don't want to put these in only to later discover why and have to take them out again. I hate rework.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 11-18-2016, 09:02 PM   #6
83GMCK2500
According to the parts manual:
5966080 - LH Upper
5966081 - RH Upper
5966082 - LH Lower
5966083 - RH Lower
There are multiple pics of each one on ebay, should be able to narrow it down.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
