Old 11-16-2016, 05:19 PM   #1
rcoman
Truck bottoming out - do I have options?
I just installed 2 1/2" drop spindles and 2" lowering front coils for the front and 5" rear lowering coils and 2" drop blocks in the back. Installed all new shocks too. I did the disc brake conversion as well. All products were from McGaughys. The ride is great but it bottoms out in the front when dropping down off the curb off my driveway or when I go over a speed bump. I'm going rather slow in both instances but when I slow way down, it does not bottom out. I talked to McGaughys and they do not have a solution. This is my first lowered truck so maybe this is what I need to expect? I understand the ride isn't going to be as nice as a modern car but I was expecting something a little better. Does anyone have any solutions? Thanks everyone!
rcoman is offline   Reply With Quote
Old 11-16-2016, 05:20 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Truck bottoming out - do I have options?
trim the bump stops in the front so that it only bottoms out prior to the tires touching the inner fenders.
Willie Makeit is offline   Reply With Quote
Old 11-16-2016, 06:32 PM   #3
Mike C
Mike C's Avatar
I didn't even trim the stops on mine and have zero issues in the front, but yours looks lower. Did you measure from center of hub to lowest part of fender before/after to see how much actual drop you got?
My truck is lowered 4 1/2" in the front and 7" in the rear, but yours looks lower. My front tires are 27" tall and don't disappear into the fender well. Rears are 29" tall but can't really compare a step and a fleet. What size wheel/tire do you have?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-16-2016, 06:44 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Rear shock relocators help with good drop shocks.
Also an adjustable track bar is needed.
Post some suspension pics so we can see what else is going on.
Keith
Convert to disc brakes.
Old 11-16-2016, 09:34 PM   #5
Benny-
I trimmed my bump stops up front. It only bottoms out now with extremely hard bumps.
1972 C/10 Cheyenne, Daily Driver. SOLD
1978 GMC K15 High Sierra.
Benny- is offline   Reply With Quote
Old 11-17-2016, 12:09 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I had the same problem with a MCGaughy's kit on my 87 and have heard quite a few others have had the same problem. Their front springs are spongy. I went to a 3/4 ton spring with a coil cut. I am going to cut another 1/4 coil to get it a little lower in the front.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 11-17-2016, 12:21 PM   #7
demian5
demian5's Avatar
You know, you did lower a truck that is old... and everything that implies
Did you:
Install c-notch? 7" in the rear should put the frame on the axle (or really close).
See if your lower ball joints were toast?
Control arm bushings wasted or loose? They are the non-rubber grease fitting screw-in type correct?
Hit the front tires with a sledge hammer and watch what makes the noise.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-17-2016, 01:06 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
I used ECE 4.5/6 drop (2.5 spindles and 2" springs, same as yours) and have all stock bump stops up front, never once bottomed out and it's very hilly here and a lot of crappy roads. I had to cut the rear bump stops.
You also need to determine what's actually hitting... a arms hitting bump stops, tires hitting inner fender, etc. and go from there... OR are you talking about the frame/underside of the truck scraping things?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-29-2016, 01:47 AM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
Stiffer shocks or springs.
Dropmember
Air ride
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
