No VIN inside drivers door, but frame
Hi y'all - I just bought a 63 chevy and rec'd a bill of sale... the guy claims he has the title but can't currently find it, so we want to do the DMV replacement title thing. And I'd like to verify the VIN...
Cannot find the VIN on the inside of door as it's supposed to be... but found some #'s stamped on the Drivers side of the frame above the A arm... attached is pic, is this the VIN? it seems like such a short number to be a vin. thanks! NM - Found it now.... thanks! Last edited by bill9000; 11-16-2016 at 07:00 PM. Reason: found problem solved.... |
Re: No VIN inside drivers door, but frame
If it were a '63 Chevy VIN it would begin with a 3C for 2wd or 3K for a 4wd.
A '63 GMC would begin with 4 digits then two letters. B |
Your screwed because that is only a partial vin, without the vin tag or title you may have some issues.
60-66 Nut
![]() ![]() Join Date: Mar 2007
If the title is in the name of the guy who sold you the truck, he can simply file for a lost title. And depending on NV state laws, he may be able to transfer the title to you at the same time. If a VIN inspection is required, that will greatly complicate the issue. Without a VIN tag to go along with the title, you have nothing but a title to a truck and a parts truck. That is assuming a duplicate title can be issued. If not all you have is a parts truck.
GUYS read the last line he added the seller found the title
![]() Join Date: Jan 2011
So does it match the partial vin on the frame?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
not sure what the deal is on the frame... but the VIN tag is actually on the cab as it was supposed to be, I dont know how it was missed when the seller checked for it before...
this is it: |
it does seem to match what is on the frame
ron |
Your good, 1/2 ton shorty,nice.
i wish my truck didn't have title issues, im glad they found it for you though
Moderator
![]() ![]() Join Date: Aug 2011
Yep, 7 digits on the frame match last seven on the VIN tag.
