11-17-2016, 06:46 PM | #1 |
67-72 C10 Identifying Bolts and their locations
What going on out there???! I own a 1967 c10 was a long bed cut the bed and frame. Anyways when I pulled the truck apart I bag and tagged everything. I noticed their were mixed matched bolts and I'm going thru cleaning and restoring parts. I bought the assembly manual but nothing about the bolt. Is there a list/pictures with measurements for bolts and where they go?
Thanks |
11-17-2016, 08:00 PM | #2 |
Re: 67-72 C10 Identifying Bolts and their locations
If you log on to LMC trucks and look through their catalog online it will show you the bolt locations but not the size. You can order anything you want, hope this helps a little...Ed
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
11-17-2016, 08:29 PM | #3 |
How you doing 7tee? I don't want to buy new bolts from LMC I have a 5 gallon bucket from 2 c10 truck full of oem hardware. I just want to know what pacifist bolt goes in what location. I just want to make sure
Thanks |
11-17-2016, 09:40 PM | #4 | |
jz
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-19-2016, 07:27 PM | #5 |
zicc1835 i took tons of photos! someone before me took it apart and put whatever bolt fit. thats a good idea ill go look at my dad's truck and take out a few bolts and match them up.
thanks agin |
11-20-2016, 08:47 AM | #6 |
Just a fyi uour local hardware stoor probably sells bolts that are newer that fit. I bought a crap ton of bolts of all sizes and used some to change my doors from philips to hex head. Makes changing door guts 100000000x easier. And its a good replacement for a worn out oem bolt yknow. Just my .02
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks |
11-20-2016, 09:14 AM | #7 | |
