Old 11-17-2016, 09:48 PM   #1
1988 1 ton
1988 1 ton's Avatar
Fuel Tank Mounting Problems
Hello everyone!
I'm installing a fuel tank in my 87, but I don't know how to get the fuel hoses attached to the sending unit on the gas tank. They seem too short, and the space is too small to get my hand in there. Any ideas without replacing the box?
1987 K20 355/465/208
1988 K30 6.2/400/205
1988 1 ton is offline   Reply With Quote
Old 11-18-2016, 09:53 AM   #2
Dannyboy1966
Dannyboy1966's Avatar
Re: Fuel Tank Mounting Problems
I just done mine, and the way I did it was, since the lines on the truck point to the tank, and the sending unit point at the lines, I just used some extra hose and made a loop under the cab. Make a loop with both ends of the hose pointing in either direction then connect them, as you lift the tank it will for the loop, worked like a champ for me. Another suggestion before your under the truck, make sure the tank brackets are set on the tank the exact distance apart that they were when you drop the tank. If not it's a pain in the a$$ to get them right, just 1/4 inch off may as well be a foot off.
Dannyboy1966 is offline   Reply With Quote
Old 11-18-2016, 04:08 PM   #3
Tash4
Tash4's Avatar
I did the same thing . longer hose & just loop it.
Tash4 is offline   Reply With Quote
Old 11-19-2016, 09:18 PM   #4
Low69CST
I bought longer hoses as well. Get fuel injection hoses. It's much more expensive. A little axle grease helps it slide onto the metal lines.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 11-21-2016, 10:46 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yes it is tough but I did mine and as long as you leave enough room to get your arm up there they will go on. Floor jack helps
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
