Old 11-18-2016, 12:59 AM   #1
rally
Temp Gauge Not Working
I've never repaired one of these and am not really sure where to start checking for any problems.
I have the gauge in the dash, but it doesn't work. I'm running a 350. Anybody know how to troubleshoot one of these? I'm hoping the problem is not the gauge and that it's just not connected or something, but not sure where to start.
1969 Custom C10
rally is offline   Reply With Quote
Old 11-18-2016, 01:56 AM   #2
demian5
demian5's Avatar
Re: Temp Gauge Not Working
First, pull the wire off the sensor, turn the ignition on and ground the wire to the engine. If the needle pegs, its a bad sender. If it does nothing, it could be a circuit board, gauge or the wire itself.
Get a wiring diagram.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-18-2016, 12:15 PM   #3
rally
Ok, thanks demian5. I'll give that a shot.
1969 Custom C10
Old 11-18-2016, 12:26 PM   #4
custom10nut
custom10nut's Avatar
Do as Damian says, and then clean you contacts. They like to get corrosion it them
custom10nut is offline   Reply With Quote
Old 11-18-2016, 10:33 PM   #5
First of all, tell us what it's doing. Is the needle pegged on H or lame at C? If it's pegged it is grounded out somewhere and if it is lame it's no power
Old 11-19-2016, 12:03 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The temperature gauge is one of the easiest to troubleshoot. Follow the instructions above and if the gauge goes to full hot then it is probably the sending unit has went bad. It is based on resistance to ground and is controlled by the temperature of the coolant in the engine.
As the engine coolant heats up the sender resistance goes lower and the path to ground resistance is reduced. This lowers the resistance on the sending unit wire to the gauge and the gauge reads hotter.
This explains why directly grounding the wire to the engine block makes the gauge go full hot or more.
The sending wire runs directly to the cluster plug on the back of the cluster. It will be the green wire on pin 6 of the plug and it will then go to the sender side of the gauge as shown by the diagram below.
The power side of the gauge comes off the fuel gauge when the key is on and
it is shown by the purple wire on the diagram. These are actually the copper strips in the cluster panel but they are easy to follow.
Name:  guage wiring.jpg
You must have a good ground on the cluster panel to the cab for the gauges and lights to work so if the instrument lights work then the cluster is grounded. Each gauge must be grounded separately also. The grounding lug should be evident on the gauge.
If you see nothing from the gauge on the test you could have a break in the sending wire or a poor connection on the firewall block where it goes into the cab by the master cylinder. There may not be any power on the gauge on the
power side of the gauge because the copper strip may be broken or the gauge resistor may be bad.
Here's a picture of one of my clusters with the gauge installed.
Name:  temperature gauge 025.jpg
If you look at the hole where the cluster plug goes in, on the left end lower row is the no. 6 pin copper strip runs to the sending side of the temp gauge and the right side of the fuel gauge feeds the power to the right side of the temp gauge.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-19-2016, 12:17 AM   #7
el_fantasma
el_fantasma's Avatar
This will make you guys laugh. My temperature gauge never moved highway, sitting in traffic whatever. Turned out the thermostat was missing. Put one in and now temperature gauge works normally.
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 11-19-2016, 04:37 PM   #8
MagmaJct
MagmaJct's Avatar
I 2nd that. My late uncle must've put a 160* thermostat in mine. Gauge wouldn't work. Put a 190* in, and it has worked ever since!
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 12-02-2016, 03:33 PM   #9
rally
Thanks for the info guys. I had a chance to test it today. The needle sits lame under C and doesn't move at all at operating temp. I pulled the wire from the sender today and grounded it on the alternator and it pegged out. So the gauge seems to be good. There's definitely some corrosion on the connector, though, so I'll clean it up and see if maybe it just wasn't connecting properly.
But in the meantime I'm also looking around for another sending unit in case it really is bad, but I'm noticing a few different product numbers that say they'll fit a 350: TS76, TS 11, etc. Anybody know which sending unit is the right one? I haven't pulled mine to see which one I'm currently running because I wasn't sure if it's going to dump coolant or anything when I pull the unit. My drain pans are full and waiting for an oil pickup.
Thanks again for the help, everyone.
1969 Custom C10
Old 12-02-2016, 03:51 PM   #10
67 chevelle
67 chevelle's Avatar
There are at least 3 different types used on a 69 c10 with a 350 engine
http://www.rockauto.com/en/catalog/c...+/+sensor,4748
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 12-04-2016, 04:34 PM   #11
rally
Awesome! Thanks!
1969 Custom C10
Old 12-05-2016, 09:25 PM   #12
John H.
John H.'s Avatar
See if you can find an original one. I have tried sending units from NAPA that look identical to the originals, but they did not work like an original. Always showed it was hot.
If you find an original, I think they say AC delco 12 volt around the edge near the threads. In many years, I have not had a bad one in all my GM cars/trucks.
John H. is offline   Reply With Quote
Old 12-06-2016, 12:38 AM   #13
FirstOwner69
FirstOwner69's Avatar
Try this link. They claim their temperature senders are the only ones that are accurate. After clicking the link, click "All Make and Model Catalog" on left, enter make and model, then year. They are listed under "Electrical Devices". I have no personal experience with these.
http://www.lectriclimited.com/mainpage.htm
FirstOwner69 is offline   Reply With Quote
Old 07-16-2019, 03:31 PM   #14
Jake1074
Jake1074's Avatar
I realize this is an older thread but it has been most helpful.
Today I replaced my non gauge cluster with a gauge cluster including a tach and vacuum. I changed the connector pins to the proper positions Everything works except the temp gauge. When grounded the gauge pegs so it’s working. I installed the new gauge sender in the thermostat housing and wonder if this location is a problem?
Still have the after market temp gauge installed as well in the intake and it functions properly.
Thoughts- suggestions?
Jake1074 is offline   Reply With Quote
Old 07-17-2019, 09:28 AM   #15
John H.
John H.'s Avatar
If the thermostat housing is aluminum you may not be able to get enough ground. Do you have a spot in the head?
The sending unit increases the ground so the gauge goes up.
Old 07-17-2019, 04:50 PM   #16
Jake1074
Jake1074's Avatar
That may be the issue - I do still have a plug in the driver side head that may work...
Old 07-05-2020, 12:36 PM   #17
Birza25
Birza25 is offline   Reply With Quote
Old 07-05-2020, 03:47 PM   #18
BigBird05
Check your "new" sender with a Ohm meter. New does not always mean good.
BigBird05 is offline   Reply With Quote
Old 07-08-2020, 05:13 AM   #19
Green Monster
Green Monster's Avatar
After chasing other culprits with no improvement, a temperature sending unit with correct resistance from Letriclimited.com addressed the false (determined by hand held infrared thermometer pointed at thermostat housing) hot reading in my 72 Blazer temp guage. It's been 4 years since installation and and then sending unit works great.
Green Monster is offline   Reply With Quote
