Old 11-18-2016, 12:15 PM   #1
cottonme173
cottonme173's Avatar
BBC Intake Manifold ID help!
Hello all!
I am tearing down my 1977 GMC C25 with a 454. I can not see the block casting numbers to help identify the motor specs. On the manifold though is this information:
GMT2
340218
F21 77
I have found many different pages for identification, but 340218 is not on any of them so far. I would like to replace the manifold (if I really need to, current one is in great condition) with something with better performance and a Holley carb. Street driver, nothing really high performance.
I am wanting to know what ports I have to make sure I get the correct intake. Also, more info on the engine would be great to have!
Please let me know if I need to give any more info to help!
-Rob
cottonme173 is offline   Reply With Quote
Old 11-18-2016, 12:48 PM   #2
DieselSJ
Re: BBC Intake Manifold ID help!
Standard early big block truck cast iron oval port (large oval, not peanut port) intake.
DieselSJ is offline   Reply With Quote
Old 11-18-2016, 01:00 PM   #3
cottonme173
Thanks for the info!
I am thinking of going with the Edelbrock Performer RPM intake 7161 and a Holley carb. What CFM would be recommended for a BB? 700-750?
Old 11-18-2016, 01:03 PM   #4
DieselSJ
Great choice on the intake. A 750 vac secondary is a great street carb. Drop a mild cam into it and you will have a really nice driver.
Old 11-18-2016, 01:21 PM   #5
cottonme173
I was originally going to do the cam, but lost enthusiasm when I was told that I would also have to replace a lot of other components?
If you had a recommendation on a cam that would be great! I am very inexperienced on the internals of the engine. I have replaced everything else over the years, but never a cam, valves, rods....etc..
Old 11-18-2016, 02:12 PM   #6
DieselSJ
I've been liking the Howards roller-retrofit stuff.
https://www.summitracing.com/parts/h...make/chevrolet
That would be great for a mild build with stock compression. You also shouldn't have to replace anything that you wouldn't already be replacing with a rebuild already.
Even if you aren't doing a rebuild, now is the time to do the cam since you will have the intake off.
Old 11-18-2016, 03:35 PM   #7
cottonme173
Well, that sure looks like a nice cam! I however, can't do that price :-)
There must be a more....budget friendly option?
Old 11-18-2016, 06:32 PM   #8
kdh454
Ditch the manifold, it weighs a metric ton - your back will thank you later. Performer RPM and the newer Air Gap are both good manifolds.
Unless you plan on making a lot of upgrades later, I'd suggest a 650cfm carb. You would have to spin a 454 past 5500RPM before you would need anything bigger. https://www.summitracing.com/parts/hly-0-80783c
If you want to do a cam, I'd suggest something similar to a Comp 260H. It will work well with your stock valve train, unlike the roller listed above.
https://www.summitracing.com/parts/cca-cl11-203-3
You'll want to replace your timing chain while your in there as well.
kdh454 is offline   Reply With Quote
Old 11-19-2016, 11:33 AM   #9
DieselSJ
I'll agree with the above that a 650cfm carb will be fine for what you want to do.
While his cam suggestion is also good, I have found that split duration cams yield better results. These engines like a little more exhaust duration. Any flat tappet cam with a 210-215 intake duration (at .050 lift) with a slightly longer exhaust duration will suit your needs and should work with the stock valve train.
Here are a few -
https://www.summitracing.com/parts/c...make/chevrolet
A little bigger -
This one is probably on the ragged edge for what you want to do -
Old 12-01-2016, 01:35 PM   #10
cottonme173
Thank you guys for responding! I do appreciate the help!
DieselSJ:
When you say "Ragged Edge" do you mean that performance wise it is more than I need? I would have to potentially replace rods, springs and such if I went with the last one?
Old 12-01-2016, 05:32 PM   #11
DieselSJ
DieselSJ:
You would potentially need to do valve springs. But that is the biggest that I would go on a stock compression engine.
