50 Years of wires to nowhere. My journey through the spider web.
Thinning out and removing unnecessary and dead wiring. Are you ready for a good laugh?
Re: 50 Years of wires to nowhere. My journey through the spider web.
That looks kind of familiar - I got to that point on my truck and ended up gutting all of the wiring in favor of a new harness.
Do you have any wires that start as one color and magically appear somewhere else as a different color? Makes troubleshooting kind of challenging, doesn't it?
Dennis '70 CST/10 '55 Bel Air wagon |
![]() Join Date: May 2016
OMG. They don't make enough beer. For that job. LOL.
That's a job for hard liquor! I'll post a pic tomorrow of my '68's under dash job, let's just say I feel your pain!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#5 | |
several! Lol! |
![]() Join Date: Oct 2009
Worse yet, mine all start as a color - but at the other end, everything ends in black. LOTSA splices and apparently the po only bought black wire...
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
What's your plan and how can we help? think about any upgrades you might want to go to so you can plan the wiring for them.
HEI ignition External to internally regulated alternator. Headlight relay mod. Electric cooling fan(s) Work off the electrical forum.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#8 | |
This was up under the dash just above the throttle pedal, and I have no clue what it is. |
![]() Join Date: Jan 2015
I just finished wiring a '70 that was a drag truck for 30 yrs! They must of thought that wire weight a ton, because they cut everything inside and outside. I built my own engine harness and bought a pretty nice light harness off the classifieds here.
If I was you(or I run into this again) post on the classifieds that you need a complete harness...someone will come to your rescue.
Jimmy Hoelzel |
#10 | |
This is what I am working with. I swapped the small block 3 speed column shift for an LS 396 t-400. After wiring is done, all I have to do is press in the U-joints and install the drive line, bleed the brakes and an altitude tune up. I dropped 9000 ft since installing the engine and I am sure it is set lean.
![]() Join Date: Aug 2004
Nice truck! I used to have a red/white 68 twin to yours. Your 396 will like all the air at lower altitude.
I'm guessing you're not in Wyoming anymore. Texas?? It looks like your PS belt isn't quite aligned, maybe just the pic.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#13 |
I moved to the Jackson Mississippi area. Good eye on the PS pump pulley. I need to flip the pulley, or get one for a long water pump set up. I will work those bugs out in time.... Good eye though!
#14 |
X2 on a new harness from American Auto Wire. Easy install and you can order it with upgrades for HEI, VSS and additional accessories.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
#15 |
#16 |
That thing under your dash was a choke filter for suppressing radio noise. We used to put those in to cut down on the whine from the alternator. They really didn't work all that well, but they were better than nothing.
#17 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Nice '67 and a beautiful engine. Have you considered ditching the flex fan for electric fan(s)?
#18 |
Yes, this is all temporary until I work the bugs out of it. At idle, sitting still during 2000 rpm/20 minute cam break in, it hit 190 degrees and I fanned water into the radiator with the garden hose and brought it down to 175 and held. I will need a shrouded electric fan because 190 is a bit much for these heads.
#19 |
When I get this together and going, I will find a frame and start work on the frame and do the disc brakes, lines, wires, bushings, fuel cell & lines, paint and mounts. When the frame is done, I will switch everything over to the new frame and leave it at that.
#20 |
Not planning on restoration or paint. It looks great with the original patina in my opinion. Once you paint over that, it is gone forever. I don't want to do that. We are a group who appreciates fade, dents and scratches. To me, each one tells a story...
