Old 11-19-2016, 12:14 AM   #1
diveplane
temp sending unit
i noticed on my 1994 v6 vortec, 2 sensors in the driver's side engine block,
what one is the temp sending unit to dashboard temp gauge, and what is the other one for? to the computer?
i need to possibly replace the sensor its giving me a false reading in cab.
will be flushing out coolant and buying new radiator hoses i have a new thermostat also to add, may as well replace these sensors.
diveplane is offline   Reply With Quote
Old 11-19-2016, 12:15 AM   #2
diveplane
Re: temp sending unit
anyone have the part number at autozone for this or ebay..
thx guys.
Old 11-19-2016, 04:51 AM   #3
oldtrucksoul
oldtrucksoul's Avatar
Mine's an 88. But, changed mine a few days ago and RA helped a lot.
https://www.rockauto.com/en/catalog/...+/+sensor,4748
oldtrucksoul is offline   Reply With Quote
Old 11-19-2016, 11:13 AM   #4
ChevyTech
If I remember correctly the vortec V6 engine had a knock sensor in each head.
Old 11-19-2016, 02:19 PM   #5
diveplane
is the sensor threads coated in a leak proof coating , so u dont need to add
any tape?
Old 11-19-2016, 02:21 PM   #6
diveplane
ah ok so 3 knock sensors on my 94 then one on the cat and 2 on each head?.
i will take a pic to show u guys what they are.
Old 11-19-2016, 02:41 PM   #7
diveplane
ok heres pics guys
passenger side has no sensors on it only 3 plugs.
Old 11-19-2016, 02:49 PM   #8
diveplane
manual it only shows me a v8 motor version not helping
Old 11-19-2016, 03:08 PM   #9
diveplane
wiring diagram think i found what they are
green wire is indeed the coolant sending sensor
but i think the one above is oil pressure sender? to dash..
not a knock sensor only one on my truck that's located at the cat.
later models were outfitted with up to 4 knock units i think.
Old 11-19-2016, 03:17 PM   #10
diveplane
think those are for manifold to computer sensors
one am looking for goes to dashboard reading in cab.
Old 11-19-2016, 03:19 PM   #11
diveplane
so am looking for part number for this and a place to buy guys..
Old 11-19-2016, 03:33 PM   #12
diveplane
is this the confirmed part here guys?
http://www.oreillyauto.com/site/c/de...1392&ppt=C0039
Old 11-19-2016, 03:34 PM   #13
diveplane
dont see any thread leak lock on that part?
Old 11-19-2016, 05:19 PM   #14
ChevyTech
The smaller sensor in your photos is a coolant temp sensor. Do NOT use any Teflon tape on it.
The larger sensor in your photos is a knock sensor. If the computer is not setting a trouble code then you should leave it alone. They often sell people the wrong knock sensor. The sensor is more fragile then it looks and people damage the new sensor when they install it.
Old 11-19-2016, 05:36 PM   #15
diveplane
can u give me the parts to buy direct fit.
link?
Old 11-19-2016, 05:40 PM   #16
diveplane
but in the wiring diagram it says oil sending pressure unit to dash,
it's really a tan wire not black like in photo i uploaded..
only one knock sensor on my truck 94 that's at the cat.
if your saying thats a knock sensor then where is the oil sending pressure to dash?
Old 11-19-2016, 06:56 PM   #17
ChevyTech
The oil sending unit is by the distributor screwed into a brass elbow.
There is no knock sensor at a catalytic converter. You are most likely looking at the oxygen sensor.
I don't know where that wiring schematic is from but it does not look like it is from GM. Even GM schematics have errors. A schematic does not give location information and just because the two sensors are next to each other in a schematic does not mean they are next to each other on the vehicle.
Old 11-19-2016, 07:03 PM   #18
diveplane
can u give us a link to the part i need to replace temp sending
as its faulty my truck needs replaced.
Old 11-25-2016, 07:31 PM   #19
Chevyaz
The orielly part you posted is the correct one.
Chevyaz is offline   Reply With Quote
Old 12-02-2016, 08:58 PM   #20
diveplane
so this will work for the dash gauge then? temp reading in cab.
Old 12-25-2016, 08:50 PM   #21
diveplane
can someone respond here ok i pulled the plug out that temp switch green wire,
and it never did anything in dash the temp gauge still makes a reading wtf is going on here?
when i turn the ignition of i think i get the correct reading as it pegs up half way mark almost, turn ignition on the needle drops down the rises a little.
i replaced my thermostat gasket upper and lower radiator hoses
i need to buy that temp sensor see if it cures.
Old 12-26-2016, 08:26 PM   #22
ChevyTech
Dash Temp gauge testing:
Unplug the sensor and the gauge should go all the way to the COLD end of the gauge.
Grounding the wire to the sensor should make it go to the HOT end of the gauge.
Old 12-27-2016, 07:44 PM   #23
diveplane
wow fixed it thx very much chevytech and other guys, new sensor in.
