11-20-2016, 05:01 PM | #1 |
71/72 front brake hoses
Seems there's some options out there but I've read that some are shorter than others. I have '84 dually disks on my '68 and need hoses.
Thanks, Jon
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
11-21-2016, 04:54 PM | #2 |
Re: 71/72 front brake hoses
Bump
11-21-2016, 05:15 PM | #3 |
'84 dually disks? What does that look like? Did you build a DIY big brake kit?
Re hoses: probably any will do provided they are the correct length. I'd take one of the old ones to a parts house and just match it with another brake line. -klb |
11-21-2016, 06:59 PM | #4 |
I had 4 wheel drums on my '68 one ton dually that I switched to disks with an '84 dually front end.
There's one of the rotors on the left. I don't have a hose from a 71/72 to match up.....
11-21-2016, 08:55 PM | #5 |
Wow. Heavy Duty.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
11-22-2016, 09:11 PM | #6 |
Nobody has a 71/72 2wd dually that can measure their front brake hoses?
11-22-2016, 09:32 PM | #7 |
I can try to measure tomorrow if it is not raining. I have a 69 I did a disc swap on with the newer rotor assy. If I recall when I did the swap, the right side was a different hose because of the drum brake hard line. The hard line had a larger tubing nut than the left side. All in all what I did was have the hoses custom made for the difference. There is no "off the shelf hose" that I know of unless you add some adapter/reducer. The next thing for an off the shelf deal is to replace the hard line going across the cross member to the T inside the frame rail.
11-22-2016, 09:42 PM | #8 |
I thought the factory hoses were supposed to be different, that's why there were two different p/n's?
