Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 11-20-2016, 06:23 PM   #1
6t727t2
Active Member
Blazer/Jimmy rear panel material
Original pass side black vinyl panel material, I think it can be re-mounted and look good. Will include a driver side piece, missing the last 12'' if you want it.
$60 shipped, pp mo
6t727t2 is offline   Reply With Quote
Old 11-20-2016, 08:42 PM   #2
68panelman
68panelman's Avatar
Re: Blazer/Jimmy rear panel material
Hey Harry, any pics of the driver side?
68panelman is offline   Reply With Quote
Old 11-20-2016, 08:50 PM   #3
6t727t2
Active Member
Driver side
Old 11-20-2016, 08:53 PM   #4
68panelman
68panelman's Avatar
Still pliable?, Not crispy?
Thanks, Mike
Old 11-20-2016, 08:55 PM   #5
68panelman
68panelman's Avatar
Hard to tell, is the cut in front, or rear area?
Old 11-21-2016, 08:40 AM   #6
1rippen6
If it gets to me a will take them.
1rippen6 is offline   Reply With Quote
Old 11-21-2016, 10:03 AM   #7
68panelman
68panelman's Avatar
I'll take them Harry.
Looks like the cut is in the rear.
Old 11-21-2016, 07:47 PM   #8
6t727t2
Active Member
Mike, they have been rolled up for a few years, I just unrolled them and rolled them up again, seemed ok. I had a similar set for 72 burb a few years ago, talked to an upholstery guy, he told me to clean them first, then use vaseline on them, I did and they turned out fine. If your not happy when you receive them, you can send them back. Thanks, Harry
Old 11-21-2016, 08:09 PM   #9
68panelman
68panelman's Avatar
I'm sure they'll be fine Harry. Perfect for a daily driver, and I plan on doing some custom tool containers for the rear area. Payment sent. Thanks again, Mike
Old 11-23-2016, 11:17 PM   #10
Frugalmeyer
What does a good set go for?
Frugalmeyer is offline   Reply With Quote
Old 12-11-2016, 09:51 PM   #11
robs71k5
K5drive
robs71k5's Avatar
I kinda wonder if a person stretched them out and pinned them to a sheet of plywood under a heat lamp might benefit a Vaseline rub . But it would sure help if that where done just to get some good digital pictures here so one might down load them into some sewing machine embosser like in baseball do on baseball caps . I would love even to have that scroll pattern in a hard vinyl so it stands up to the abuse and easier to keep clean.
robs71k5 is offline   Reply With Quote
