![]() Join Date: Nov 2016
Borg Warner T5;
What should be the top speed for a 230 - T5 combination? My truck came with a 3 on the tree, and to get overdrive, I adapted a Borg Warner T5 five-speed into the drive-line.
I am unsure about the rear-end gearing ratio, but it did come with a dealer tow-bumper, and somewhere along the line, picked up a posi-track. Still, if my truck had particularly low gearing, it should start rolling in first even at an idle, right? I anticipated that it would start rolling with little effort, but actually I really have to give it the gas in first to get going. I also expected to reach a top-end of around 70 mph, but from listening to the engine, I felt I was revved up enough already at 60 mph. Thoughts / Comments? Thank you. Have a good day. |
Re: Borg Warner T5;
Depends not on the engine but on the version of the T5, (they didn't all have the same overdrive ratio), your rear gears, and tire size.
You have to know those components and do the math to calculate speed at different rpms.
292 + TKO500 |
#3 | |
Re: Borg Warner T5;
I suspect you have an S10 T5 with 4.03 first gear and that's why the truck barely gets moving before you need to shift. I hope you are not experiencing clutch slippage. For top speed at 60MPH I also suspect you might have a 0.86 overdrive gear. It would be nice to know what your engine RPMs are at 60MPH.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Re: Borg Warner T5;
Zimme
Also would be curious how you are measuring your speed? Likely your speedometer is way off using speedo gear in the T 5. Best way is to use GPS or speedo app on your smartphone. Hope that helps. Steve New Orleans |
Re: Borg Warner T5;
My 292/T5 combo cruises no problem at 70 and will reach 95 MPH before it runs out of juice. I have a T5 from an S10 with what I believe is the 0.86:1 5th gear ratio and 235/75r15 tires.
I enjoy driving it for sure ![]() |
#6 | |
Re: Borg Warner T5;
If it's struggling to get moving even with that combined first gear ratio then the problem is in your motor. It has all to do with not enough timing. Your motor is fighting itself trying to run. What's your initial timing? |
#7 | |
Re: Borg Warner T5;
If I understand the OP, he has to get the RPMs fairly high to get the truck rolling - which makes me think the clutch disc is slipping. If the clutch and flywheel are working properly, the truck should move even at low RPMs (1000 - 1200) no matter what the timing is (within reason).
Re: Borg Warner T5;
If the motor has no power due to a lack of timing it won't pull the truck even off idle in first. With that gear combo in first (likely close to 12 to 1) you should be able to side step the clutch and not kill the motor and it should just idle along.
With retarded timing the motor isn't making enough power to accelerate without struggling. |
#9 | |
Re: Borg Warner T5;
Re: Borg Warner T5;
Nah!!
If he really needs to give it gas in first to get going, the rpm would overpower the clutch if it was slipping. He'd be sitting there smelling the clutch going nowhere. |
Re: Borg Warner T5;
I think I'm losing this debate! LOL! I hope the OP adds some more info.
Re: Borg Warner T5;
Bottom line is the ponies are kind of small but I agree with geezer, get as much out of the engine as you can. It will run better with HEI ignition and maybe more advance.
#13 |
Re: Borg Warner T5;
#14 | |
Re: Borg Warner T5;
When I installed a fresh 230ci, I mistakenly had my initial timing advanced over 30. Yep. Over 30. Lacked power at higher RPMs. BUT . . . . I didn't have any problem with getting it moving, or driving 70 MPH. Noticed poor acceleration and not very peppy. My thinking is this - 1500 RPMs at the flywheel (bad timing or not) is still 1500 RPMs. Sure, it may lack power and not want to move without trying to stall under a load. But the OP sounded like the truck just wasn't moving AT ALL until the RPMs were very high. Please don't think of me as argumentative. I'm not convinced of anything at this point. Maybe it's just me and how I am interpreting his original post. I'm here to learn, contribute when I can. It also helps me.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 11-22-2016 at 10:33 AM. |
#15 | |
Re: Borg Warner T5;
Why don't you test it first hand and let us know? |
#16 | |
Re: Borg Warner T5;
I would be happy to test mine but it's on jack stands undergoing power steering upgrade, disc brakes, etc. I sure wish the OP would add jump back in and add info.
#17 |
Re: Borg Warner T5;
Probably most people that have had a worn out clutch will tell you that they first show symptoms in high gear, not first gear.
#18 |
Re: Borg Warner T5;
Good evening, and a happy Thanksgiving to each of you and your families.
Please overlook my delay in adding more info here. I'm a senior pre-med student facing finals and research project presentations.. and so on. As for my believed speed, my roommate was following me on the highway and said I was doing 60. I don't have any speedometer, as my dash gauge is mechanical and the S10 T5 (1991) has an electronic pick up or sensor. |
#19 |
Re: Borg Warner T5;
My truck has a new 11 inch clutch and a new 11 inch, 14 spline pressure plate. I don't think it was slipping.
#20 |
Re: Borg Warner T5;
And your initial timing is???
#21 |
Re: Borg Warner T5;
About the initial timing, I am unsure. How do I check it? If the only way is with a timing light, I don't own one.
#22 |
Re: Borg Warner T5;
It was necessary to replace the rims so I went with 15x8 rally wheels. I forget exactly what size tires are on them, but believe that they are 255 r60 x 15.. and if I remember correctly, are about 27 inches tall.
#23 |
![]() Join Date: Nov 2015
Re: Borg Warner T5;
For a timing light find a Harbor Freight. I bought one from there and it seems to work great. Setting timing was much easier than I thought; I just had to watch a couple of youtube videos.
#24 |
Re: Borg Warner T5;
Like this one.
It's for a sbc but the principals are the same. https://www.youtube.com/watch?v=UYGU7mTwsZc |
#25 |
Re: Borg Warner T5;
I confirmed that a 255/60R15 is indeed a 27" in diameter using another web site.
I use THIS LINK to calculate engine RPMs. So when you were doing 60 MPH your RPMs were as follows depending on what rear diff you have. If your 5th gear is 0.86 then: 3.08 rear diff = 1978 RPMs 3.42 rear diff = 2196 3.73 rear diff = 2395 4.10 rear diff = 2633 with the 0.72 5th gear then: 3.08 rear diff = 1656 RPMs 3.42 rear diff = 1839 3.73 rear diff = 2005 4.10 rear diff = 2204 So none I what I say next is fact of course. I'm thinking that you have the 0.86 fifth gear and a 4.10 rear gear. Possibly a 3.73 rear. Those are the only numbers that get your RPMs high enough. Most T5s with a 0.86 overdrive have a 4.03 first gear. So using the same RPM calculator as before, your first gear or 4.03 combined with a 4.10 rear would mean that at 15MPH you would have 3084 RPMs and that would make you want to shift. Again, this is all an assumption. With a 4.03 first gear and a low rear end, the truck should begin to roll with barely any pedal but you will find yourself needing to shift rather quickly. Is that what you experience? Your original post sounded like the truck wouldn't move AT ALL unless you really gave it a lot of gas. It's sounding more and more like you have a lack of engine power.
