10-11-2003, 12:24 AM | #1 |
its all about the +6 inches
Engine casting number ID?
I got these numbers off the machined pad on the passenger side front of the engine. (under the alt with a long water pump set up)
I can never seem to be able to decode them with these numbers. I don't know if I am going to the wrong sites, or just not looking on the sites close enough... VO726FRS is stamped on top, and directly under that is CFS198728. On the bellhousing it says 5.7, but I never looked for any codes up there last time the engine was out. Can anyone tell me what my 350 is out of? |
10-11-2003, 01:43 AM | #2 | |
Bloo
are you SURE thats what it says? ive looked on the normal (nastyz28.com) and googled for it and cant find it anywhere, FRS would be your suffix code in that
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
10-11-2003, 09:44 AM | #3 |
Inline 69
uhmm,im confused also,,,from what i found ..VO726FRS,comes back as a "1986", 350ci, c20/k20 ,flint,july,26..is this a short block,,,,it should have pollution controls on it...jeff
10-11-2003, 02:02 PM | #4 |
huh?
That would make sense, I believe Andy said he thought it was an 87-ish block in another post.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
10-11-2003, 07:14 PM | #5 |
86 sounds about right. Thanks.
Where did you decode it? Smog stuff unbolts pretty easily. I bought it as a long block with a couple extra items on it, in reality it was basicly a complete engine without an intake/carb/dist, nor fuel pump. It even had good truck motor mounts, but he wanted to keep them. Thanks again. |
